Wheel fitment
Old Mar 24, 2022 | 12:21 PM
Airwreck567's Avatar
Airwreck567
3rd Gear
Wheel fitment
will second gen lightning wheels fit a a 4wd 1994 f-150 5.0 ? if not, will converters work ? if so which brand do you guys recommend ?
Old Mar 24, 2022 | 12:36 PM
SFaulken's Avatar
SFaulken
I think the bolt pattern is the same, but the backspacing/offset is going to be all wrong.
Old Mar 24, 2022 | 12:42 PM
Airwreck567
3rd Gear
So there is no way i can make this work ?
Old Mar 24, 2022 | 12:46 PM
tommywvk's Avatar
tommywvk
No super good way to tell definitively unless you go and try and fit them to your truck. Only then will you get an accurate answer.
Old Mar 24, 2022 | 01:04 PM
Conanski's Avatar
Conanski
The bolt pattern is slightly different, that can be addressed by drilling out the holes slightly larger however the wheel offset is all wrong for these older truck so a better solution may be a set of 2" wheel spacers with the correct bolt pattern.
duggy2145
Oct 23, 2015 10:14 AM
lawnspecialties
Jan 26, 2014 08:27 PM
Clarkbug
1983 - 2012 Ranger & B-Series
Oct 24, 2011 01:40 AM
FORDFAN70
Aug 16, 2006 11:06 PM
superman71
1966 - 1977 Early Broncos
Jul 25, 2003 09:41 AM
