DEF fluid freeze point?
Old Mar 22, 2022 | 11:28 AM
7.3F350's Avatar
7.3F350
At what temp does DEF freeze? I have many diesels, but none that run DEF.
I watched this video this morning and "Guy" said that in his neck of the woods (Wyoming), DEF freezing up is a common problem.
Here in balmy TX, I rarely hear of this "issue".
Old Mar 22, 2022 | 11:36 AM
Doc Foster's Avatar
Doc Foster
8th Gear
11 degrees F - https://www.motortrend.com/news/2001...0its%20quality.
Old Mar 22, 2022 | 11:49 AM
4wd6.7L's Avatar
4wd6.7L
I have not watched the video yet, and don't live in a cold area, but there are a lot on here who do. Some that run these trucks in a much colder environment than the freezing temp of DEF (which is around 12 deg. I think). The only time I've heard of temperature related DEF issues is when there is a problem with the DEF heater.
Old Mar 22, 2022 | 01:10 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Guy in WY video
Yeah, 11 F, 10C freeze point, but there is a heater in the DEF tank and the injector line is heated as well.
Old Mar 22, 2022 | 08:02 PM
PullingMalibu's's Avatar
PullingMalibu's
Out of curiosity, does the def tank and line heater, heat with the block heater plugged in? If not, how to we keep the def from freezing over night, etc.
Old Mar 22, 2022 | 08:11 PM
4wd6.7L's Avatar
4wd6.7L
As far as I know it does not heat from the block heater. The DEF heater heats when the truck is running. Ford states not to overfill the DEF tank for this very reason, because it freezes. As long as the DEF heater and heated line is functioning properly, the fact that DEF freezes does not appear to be an issue. At least not from what I've read from Ford.
Old Mar 22, 2022 | 08:36 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
No, block heater has nothing to do with DEF heater.
DEF tank heater is part of the pump assembly, operates when the truck is running and it is called for due to temperature.
Truck is set to operate normally until the heater provides enough liquid DEF to be pumped.
Old Mar 22, 2022 | 09:35 PM
440 sixpack's Avatar
440 sixpack
I've been in -20 to -30 numerous times and never had a problem. I did see a friend's new 2020 F350 freeze up once and I believe it was caused by ice building up under the tank and -25 temps. the dealer left it in the shop overnight and it's been fine ever since.
Old Mar 22, 2022 | 10:47 PM
jollyrogr's Avatar
jollyrogr
The truck empties the DEF line when you shut down so that the line doesn't freeze. The pump and the line have heaters. The heaters are turned on when the DEF "approaches 12 degrees F"
jimzpsd
Mar 16, 2022 11:12 AM
Jerseyman32
2004 - 2008 F150
Oct 17, 2021 11:16 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 11, 2008 08:38 AM
Mike-G
Mar 1, 2008 01:48 PM
