thicker viscosity oil
just pondering if using thicker viscosity oil would help with the oil evaporation that winds up coating the intake and components as well as contaminating Nox and OS sensors. In digging into this another benefit would be less fuel dilution.
its one thing to find higher viscosity oil, but also finding one that is on fords approved list may be another story.
food for thought
this BIO oil seems to be the highest viscosity oil so far.
it comes in a few different weight grades (5W40, 10W30, 5W30, 15W40, etc)
food for thought
food for thought
food for thought
You talking for use in the warm weather right?
i run valvoline 15w40 in my cummins ISC and since i buy cases at a time, its also what goes in the 6.7
both engines have DPF, the cummins has 55 gallon drum dpf and gets HOT HOT
the torpedo in the 6.7 has a hard time ever getting to 500 f
oil is low ash and meets requirement for ash .
6.7 seems to not mind using the oil.
food for thought
food for thought
The following users liked this post:
Sounds like you want to prevent oil mist from coming through the crankcase ventilation and into the intake? I've tried reducing this effect on an older gasser by varying the oil viscosity and even tried couple different brands with zero luck. The only environmentally good way I found was to add a catch can. That also allowed me to stay with the recommended oil viscosity.
That's the oils pour point. That does not mean in below freezing temp that your engine would not have a hard time pumping it thru a cold engine. Also when cold, the higher oil pressures may cause the by pass on the filter to open allowing unfiltered oil to circulate. a 15W40 and a 5W40 are both 40W at operating temp.
With the designs of the newer motors and the close tolerances they are built by they recommendi running any higher viscosity oil than the book recommends. What they say happens is the oil doesn't flow good enough to get into the bearings and could cause engine failure. It also makes the oil pump work harder which causes the motor to work harder to pump the oil. I'm still using the full synthetic 5/40 @ 70,000 miles I am having no issues with my motor. Still al stock. No added filters but I would like to add the catch can because that would be a good idea.
I always fill 1 Qt low so that my level on the dipstick is at the very bottom of the dipstick range.
1qt divided by 14qts comes out to just below 7%
which means..if the oil level creeps up to full due to fuel dilution in the oil, in at about 7% .
this is just a heads up for me…time to change my oil no matter the miles or what the ford oil change lie o meter says.
