I need help. E brake?
Old Nov 7, 2003 | 02:21 AM
89ranger's Avatar
89ranger
Ive got a 89 ranger. the e brake wont release in cold weather. How can I fix this problem. Also would the cable be stretched??
J.
Old Nov 7, 2003 | 05:40 AM
Dealford's Avatar
Dealford
Have you tried to lube the cable at all?
Old Nov 7, 2003 | 08:20 AM
jessfactor's Avatar
jessfactor
they say that ur not supposed to use ur e-brake in freezing weather. i personally dont trust 1st gear to hold the truck on a hill without any help. i would try dealford's way and lube up all the moving parts.
Old Nov 7, 2003 | 10:11 AM
89ranger's Avatar
89ranger
what kinda lube should I use?? and were can I get it?
J.
Old Nov 7, 2003 | 11:47 AM
junction99's Avatar
junction99
I have heard of a speedometer cable lubricant that is supposed to run through the cable and lubricate a cable with a sheath. I've been told that it is an oil with a lot of graphite in it. This would be your best bet to lubricate the cable itself. I haven't found any yet but I have only checked two places so far. I am planning on checking with a dealership or two if I can't find it at a parts store. Hope this helps.
Old Nov 7, 2003 | 11:49 AM
junction99's Avatar
junction99
For everything else your best bet is a white lithium grease spray. You can find that at any local parts store or your local Wal-Mart. Cost is about $2.00 a can.
Old Nov 7, 2003 | 12:08 PM
89ranger's Avatar
89ranger
ok, I'll try the spry grease. Tell me if this might work. Take the e brake cable and run it threw a pipe so that ice and snow wouldnt get to it.
J.
Old Nov 7, 2003 | 02:34 PM
Ken00's Avatar
Ken00
The shoes freeze to the drums in cold weather, thats the most common reason for them to stick.
