1966 - 1977 Early Broncos
VIN decoder
Old Mar 18, 2022 | 10:57 AM
S_pyle2001's Avatar
S_pyle2001
VIN decoder
U15GLY60198
Trying to decide this VIN bought it and found a rod went through the oil pan. I will need a new motor and would like to get it close to original as possible. Thanks in advance for any help here.
Old Mar 18, 2022 | 07:24 PM
85e150's Avatar
85e150
U15 = U150 model, 4400 lbs GVW, U100 wagon
G = 302 2V V8
L = Michigan Truck Plant
Y60198 = 1977 numerical series, May 1977 build date
Source:
http://www.broncohio.com/tech/ebvins.html
Since you will need a whole new long block, do yourself a favor and get a the latest F150 or Mustang roller 5.0 you can find.
You can retrofit your front cover, water pump, probably even valve covers etc, along with the 2bbl manifold. If you are clever, you will add 100 hp without anyone being able to tell.....
Old Mar 19, 2022 | 10:00 AM
S_pyle2001's Avatar
S_pyle2001
Much appreciated!
Thanks for the ideas and the information on my VIN.
I'm sure I will be back on here with more questions as the build goes on.
Since the motor was shot we decided to do a frame off rebuild. I'm not rich by any means so it's going to be a slow process.
Old Mar 22, 2022 | 09:19 AM
svastano's Avatar
svastano
Another source for re-building this beauty is classicbroncos.com I frequent there also.
N61870
Large Truck
Nov 12, 2021 09:38 AM
Steve Noland
Dec 16, 2016 11:40 AM
