Recommended maintenance at 200K miles?
Hello all,
I bought a 2015 F250 this past October with 181,000 miles on it. It is now nearing 200K and I was wondering what maintenance is advisable and should be performed? Since buying, I have done oil changes and fuel filter change. My last diesel was a 92' 7.3 IDI so I am relatively unfamiliar with these newer engines.
It seems the truck was serviced regularly at proper intervals prior to this at Ford dealerships, but I don't have actual records of what was done.
I plan to:
1) Flush orange coolant and switch to yellow
2) Replace trans filter
3) Replace air filter (I think its original)
4) Replace belt and tension and idler pulleys (I think its original)
Open to suggestions on what else to do?
I plan to:
The following users liked this post:
Check the brake fluid. Maybe do a fluid flush there. That stuff gets gunky also.
Fuel filter change; the one on the frame (diesel fuel conditioning module) and the HPFP (high pressure pump) under the hood.
https://www.dieselfiltersonline.com/...and-parts.html
I would call the dealer and give them your list and see what they would charge for all the fluid changes. It's a pain to depose of all the different fluids. You can change fuel and air yourself. I have replaced my air filter 3 times already so you are over due. LOL Good luck with your truck I love my 15.
I'd also like to add that I monitor the fuel pressure from the DFCM (which is measured at the HPFP) on my iDash. If I see any significant drop in pressure, I'd check on that lower primary filter. I let the truck tell me when to change the oil (usually at about 7.2k miles). The Ford manual says to change the fuel filters every 3rd oil change or by 22.5k miles. That's when I change mine. Just FYI.
Received 1,518 Likes
on
The two that I know of are the front axle u-joint fittings. Check the steering fluid see how dark it is and smells. I've been wanting to do a steering pump flush and fill since last year.
The following 2 users liked this post by FishOnOne:
That's actually a good idea instead of **** ing with the out fitting on the steering fluid cooler. Thanks.
hitecdan
Oil & Lubrication
08-14-2002 12:45 PM
