Eco mode
Old Mar 10, 2022 | 09:06 PM
2five7's Avatar
2five7
Wish Ford would add in the ability to choose eco as the default drive mode, and also have the option to have the truck auto switch to tow/haul when a 7 wire trailer is plugged in.
Old Mar 10, 2022 | 11:09 PM
Falcon67's Avatar
Falcon67
Only about 50 miles on the 2022 Lariat F-350 7.3 but Eco Mode acts different than it did in the 2020 F-350 7.3. Be awhile before I can tell if there is any difference in MPG.
Old Mar 11, 2022 | 09:39 AM
acadianbob's Avatar
acadianbob
I think Eco is a benefit with continuous use in day to day conditions. It seems like it short shifts and takes a little reaction out of the throttle pedal. But I bet that a pure long distance road trip it would make no difference. I use it a lot. I do get tired of having to constantly tell it to retain Eco mode.
Ford can't win. If you automatically enabled tow/haul with the 7 pin, then people would complain about that.
Old Mar 11, 2022 | 09:47 AM
2021F350's Avatar
2021F350
With 1,200Lbs in the back for winter traction I got... In three exact same trips, there and back road clear...
T/H mode; 15.9 MPG
N mode; 16.2 MPG
Eco mode; 16.7 MPG.
With todays gas prices around here I would save $6.85 using N instead of T/H mode per tank, $11.20 per tank using Eco instead of N, $18.27 per tank, using Eco instead of T/H...
Last edited by 2021F350; Mar 11, 2022 at 10:23 AM. Reason: add some extra thoughts
Old Mar 11, 2022 | 08:43 PM
CountryRN's Avatar
CountryRN
Trailering
Eco mode on a 3 hour trip through the external part of NC. Flat 2 lane driving for the most part. I was very impressed with the mileage. It's better than my 06 F150 4x4 crew with a 5.4.
2022 F250 CCSB 4x4 with 7.3 and 3.55. Empty run for 137 miles. Best mileage noted on the trip was 19.2.
Old Mar 11, 2022 | 09:09 PM
Falcon67's Avatar
Falcon67
Doing good the get 11 on Eco, but truck is new so it needs sine run time. 7.3L 3.73 DRW 4x2. The 2020 got around 12 here.
Old Mar 12, 2022 | 03:06 PM
Lux194's Avatar
Lux194
I have the same configuration, so that’s encouraging. I’d be thrilled with 15 MPG that is a bit of a mix between town and highway.
Old Mar 13, 2022 | 03:59 PM
2021F350's Avatar
2021F350
T/H mode; 15.9 MPG
N mode; 16.2 MPG
Eco mode; 16.7 MPG.
Took out the 1,200Lbs and did the same trip again today...
Eco mode; 17.1 MPG.
Old Mar 13, 2022 | 04:06 PM
chadstickpoindexter's Avatar
chadstickpoindexter
For those posting pics of the in dash MPG, have y'all hand calculated it to make sure they are correct? My driving is mostly stop and go in the city, and regens about every other tank, so I haven't came up with much of anything consistent, however, the trucks average has never matched the hand calculated average, which I do every time I fill up. The truck always displayed more than what I came up with... I also came across a thread recently pointing out how to change the AFE setting on the truck to try and get the trucks readout to read more correctly. I have made small adjustments to it the last 3 times I have filled up, however, I doubt it will ever be correct.
Old Mar 13, 2022 | 04:29 PM
2021F350's Avatar
2021F350
I had to change mine from the 1,000 down to 930 to get it to read "right", to show the same as the "actual" measured/calculated amount from the fill ups...
Old Mar 13, 2022 | 04:41 PM
chadstickpoindexter
After doing the recommended math I changed mine to 922. Then it read low, so I bumped it up to 927 and it still read low so the last time I filled up I went to 935. So we’ll see. I figure with the inconsistent driving it will never read correctly… especially when I start towing more!
DaveKellieF350
Jun 5, 2019 01:49 PM
FTE Herman
Apr 6, 2018 12:53 PM
tristankc
Jun 10, 2016 02:36 AM
jdadamsjr
6.7L Power Stroke Diesel
18
May 2, 2012 10:43 AM
Bill F Wright
Dec 11, 2008 06:04 AM
