Custom Cab Emblem Location
Old Mar 8, 2022 | 06:36 PM
jtolle's Avatar
jtolle
4wd Low
Hello Everyone,
First off I'm a new member on this site and my name is John. I recently purchased a 1966 Ford F-100 short bed truck that has been restored pretty well except for the minor mods I will make. The truck was missing the emblems on the sides that had been removed and filled. I was able to get the location for the fender emblem on these threads which really helped. Would anyone have the hole locations for the custom cab emblem. I can eyeball them but a measurement would make life easier.
Thanks
John
Old Mar 8, 2022 | 06:40 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Have the holes been filled with Bondo or steel? If Bondo you can go inside the door and feel around for the Bondi dot and tap it with a small hammer, from the outside. If it's steel, well. I can measure my doors. I'll have to get back to you though
Old Mar 8, 2022 | 06:54 PM
jtolle's Avatar
jtolle
4wd Low
Thanks for getting back at this point I don't know I will be removing the access panel soon so I can check it could go either way for sure although the rebuild was done well. I can let you know once I check. It will be over the weekend most likely.
Thanks for the help
Old Mar 9, 2022 | 03:51 PM
Thunderkiss1965
Sitting in traffic this morning I remembered your post, the door logo is level with the door handle and is approx two inches in front of the same. As far as the holes go, I can't say with the thing installed.
Old Mar 9, 2022 | 04:57 PM
jtolle's Avatar
jtolle
4wd Low
Thanks that helps otherwise i’m guessing since can’t find anyone local with a truck that old
Old Mar 9, 2022 | 09:41 PM
mitzel's Avatar
mitzel
4wd Low
I just put a tape measure across my '66 F250 driver door, from the front edge to center of first hole (post for the 'C' in Custom) I'd call it ~13-7/16". On the passenger side the front edge to first hole (post for 'b' in Cab) was ~13-5/8".
Old Mar 10, 2022 | 01:53 AM
jtolle's Avatar
jtolle
4wd Low
Thanks for measuring that out for me it will really help locating the emblems in the proper spot
Gcwstang
Vehicles for Sale
Jan 5, 2016 12:08 PM
Coupleofords
May 13, 2009 08:56 AM
biggut
Mar 2, 2009 06:42 PM
my58vw
Dec 16, 2002 06:36 PM
