Sponsored by: Auxito
Check Engine Light
Old Nov 6, 2003 | 06:08 PM
djadams's Avatar
djadams
Check Engine Light
What in the emissions system turns on the check engine light? And can I reset it?
Old Nov 6, 2003 | 06:54 PM
ricks01's Avatar
ricks01
o2 sensors or cats most likely.. what is the code? take to auto zone they will read it for free and can clear it...if not, disconnect the bat(pos and neg) turn the key ON and step on the brake for 20 secs...reconnect the bat, then expect it run funny till the pcm relearns....best way to treach it is run it in parka/c off then on for like 60 seconds,. then do the same thing in reverse...
Old Nov 6, 2003 | 08:25 PM
Racerguy's Avatar
Racerguy
Hi djadams and welcome to FTE
If you do go get the system scanned at Autozone like Rick suggested please get the code number and not just the description of it. It will be a P**** code. It makes it a lot easier for us here to figure out what the problem might be. There are numerous sensors and outputs that can cause the light to come on.
What year is your truck? How many miles on it? What size engine?
Old Nov 7, 2003 | 10:03 AM
djadams's Avatar
djadams
check engine light
Hey, thanks for all of the input, I will give your suggestions a try and let ya'll know, I drive a 97 f150, with the 4.2L V6
Old Nov 7, 2003 | 01:21 PM
Jupiter Coyote's Avatar
Jupiter Coyote
EGR valve???
Old Nov 7, 2003 | 06:08 PM
djadams's Avatar
djadams
Check Engine Light
I just got back from autozone and they said it was a plug 4 misfire
Old Nov 7, 2003 | 11:54 PM
Racerguy's Avatar
Racerguy
That should be pretty easy to fix
Hopefully it's just a spark plug or wire.
Could be a vacuum leak or some other mechanical problem but try the basics first.
