So here's a question. I picked up a 1987 f150 to pull the engine from to replace my knocky one. I noticed it has intermittent wipers on a switch just like the bullnose one. Would it be possible to swap said switch over to the bull and voila intermittent wipers!? Or is this just a pipe dream? 🤔
Oh yes it is nice as I do use them from time to time.
As said unplug the box from the parts truck harness, undo ground wire, pull switch from dash and that switch & box goes into your truck the same way it came out.
As they say plug & play
Dave ----
It is right at the switch.
It has 2 short leads on it that go between the trucks harness and the switch.
When you get under there and look you will be well why didnt I look before asking
The switch has to be for intermittent wipers to work with the box and why both have to come from the same truck.
Dave ----
