Sponsored by: Auxito
need help
Old Mar 2, 2022 | 08:17 PM
kennymc1969's Avatar
kennymc1969
need help
i have a 2000 f150 truck stopped running could not hear the fuel pump prime checked all fuses and relays put a new fuel pump in today and its still not working can somebody help
Old Mar 2, 2022 | 08:49 PM
Jon Freeman's Avatar
Jon Freeman
Check the inertia switch.
Old Mar 2, 2022 | 09:08 PM
kennymc1969
i did its ok
Old Mar 2, 2022 | 09:48 PM
Jon Freeman
So, the engine will crank but not start ?
Have you checked for fuel pressure, at the valve on the fuel rail. ?
Did you also change the fuel filter ?
Old Mar 2, 2022 | 11:44 PM
kennymc1969
yes changed the filter and theres no pressure at the fuel rail
Old Mar 3, 2022 | 12:16 AM
Jon Freeman
You'll need to verify that there is power at the fuel pump.
Old Mar 3, 2022 | 08:47 AM
kennymc1969
Got power to pump took the pump out and hooked to the battery and it works
Old Mar 3, 2022 | 10:42 AM
Johnny Paycheck's Avatar
Johnny Paycheck
You’re going to have to check for power at the harness itself. It’s possible the plug at the tank end is damaged. Maybe someone with a manual can chip in a schematic.
(That’s a lot of work to do if that’s all it turns out to be...)
Old Mar 3, 2022 | 10:11 PM
kennymc1969
have power at the connection.could it be the crankshaft position sensor
Old Mar 3, 2022 | 11:45 PM
Jon Freeman
Possibly, Do you have any codes ?
Although, if you have power at the pump it should prime. I don't think any other sensor is required for the pump to prime. Only need to turn on the ignition without starting. Someone will tell me if Im wrong.
Old Mar 4, 2022 | 08:37 PM
pdqford's Avatar
pdqford
Crankshaft position sensor won’t keep the fuel pump from cycling at “key on” time.
Having power at the fuel pump connector at “key on” time is good.
But does the ground at the fuel pump connection get pulled to ground when the PCM cycles the pump for three seconds at “key on” time?
Old Mar 5, 2022 | 10:58 PM
kennymc1969
i know this is going to sound stupid but for the last 2 nights when the is colder outside the truck will crank and run but when it a little warmer outside it wont
Old Mar 5, 2022 | 11:50 PM
Jon Freeman
So if it will start then the fuel pump is working. It primes and there must be fuel pressure. Might help to know what the fuel pressure readings are. Have you checked for codes ?
Old Mar 6, 2022 | 01:33 PM
kennymc1969
only code showing is the o2 sensor
Old Mar 6, 2022 | 04:00 PM
Jon Freeman
The O2 sensor should not stop the engine from starting. Other sensors are apparently OK. It's important to eliminate the fuel pump as a variable.
Earlier, you indicated the fuel pump could not be heard cycling on. It would be very helpful to know if the fuel pump is consistently cycling on in the "key on" position.
If it is consistently cycling on, then it would be helpful to know what the fuel pressure is when the engine starts and when the engine doesn't start.
