FORScan Question
Old Mar 1, 2022 | 09:49 AM
Beast2.0's Avatar
Beast2.0
FORScan Question
My question is this, I did the 2 month license back when I first got my truck in 2018. Made the changes I wanted and haven't done anything with FORScan since. Fast forward to now, I want/need to disable TPMS. Do I have to start over again with FORScan or just renew license and re-connect to truck? And I do not need internet access to make changes to the truck, correct?
Old Mar 1, 2022 | 11:18 AM
superduty4x4's Avatar
superduty4x4
I'm sure your current version of Forscan would be fine, but it takes very little time to download the latest version just to be sure. And yes, you'll need to request/install the temporary extended license. No you don't need internet access to connect to the truck.
Old Mar 2, 2022 | 03:28 PM
speakerfritz's Avatar
speakerfritz
anyone have the link to use your vin to get your as built data file?
thanks
Old Mar 2, 2022 | 05:42 PM
superduty4x4
That info can be found in this thread - https://www.ford-trucks.com/forums/1...readsheet.html.
Scroll down to "how do I find my vehicle's As Built Data?"
Old Mar 2, 2022 | 07:00 PM
speakerfritz
Is the spreadsheet some thing that gets imported or is it just a reference document?
Old Mar 3, 2022 | 09:53 AM
Poncho450's Avatar
Poncho450
When you go to use FORScan again it won't allow it if your 2 month license has expired. I've had it happen many times because I don't use it very often. But it's easy enough to go through the process again and renew it for 2 more months. I've also done that several times.
It's just a document that tells you what values to change on a particular line to affect the changes you'd like to make.
Old Mar 16, 2022 | 03:04 PM
Beast2.0's Avatar
Beast2.0
I got my new 2 month license and was able to 'disable' TPMS in the drop down for BCM. Question I have is do I need to go into the as-built and do change also? Reason I ask is that it is off with no alerts but still shows on display with no pressure readings when I scroll thru the display.
Flip4ford
Kansas Chapter
22
Jul 24, 2017 07:53 AM
FordmanNJ
All Things Towing
Aug 7, 2015 11:01 PM
fishforlife2007
18
Feb 15, 2015 02:31 PM
Stroker 94 1/2
Sep 9, 2006 03:10 AM
