Help! EFI exhaust bolt up problem?
Old Nov 6, 2003 | 04:46 PM
cdherman's Avatar
cdherman
OK, so now I have my EFI split exhaust heads to replace my cracked stock manifold. I think I have figured out how to plumb a heat plate under the heat riser.
But I read a post that the early heads do not have all the bolt holes necessary to attach the EFI exhaust headers? Say it isn't so!! After all this effort.
I have a 240 head from about 1965 (69?), so its definitely old. Is there any way to attach the EFI exhaust manifolds? I really do NOT want to drill any new holes in my head! (pickup or otherwise)
Anyone have this problem?
later....
Old Nov 8, 2003 | 10:41 AM
troposcatter's Avatar
troposcatter
They will bolt up, without serious modification, there is a flange you will have to grind off, fit it up with the intake first and you will see what needs to be done its easy.
