On my '21 with 302A, when I have it on the nav screen, there's a thin vertical black bar on left of screen that says menu at top. How do I get rid of it? It wasn't there to start with, sure don't need it hiding that part of the screen, I have the buttons below if I want to change screens.
A picture would be helpful because it sounds like a problem instead of a setting.
I’m not sure if you’ve tried this or not but, since you said that it wasn’t always there, have you tried a Master Reset of the SYNC 4 system?
Are you using Android Auto because that definitely looks like part of that Interface.
No, I haven't tried that, I'll check into it. I'm using Iphone X. It appeared after I had to re-connect my phone.
Well, I found out how to do a reset, that didn't do it. Searched for how to do a master reset but when I hit settings there is no place to select reset. How the heck do I do it?
