Sponsored by: Auxito
Front end job
Old Mar 3, 2022 | 07:46 AM
truckguy92's Avatar
truckguy92
Originally Posted by J. Bruce
When I did the front end on my truck the larger idler arm was the size I needed (97 150 4x4) I think it was 3.5 inches between the bolts. So the smaller size could be for 2wds
so it’s based on 4wd or Rwd?
Old Mar 3, 2022 | 08:44 AM
manicmechanic007's Avatar
manicmechanic007
IMHO yes on the Ford Idler arm
However if your kit comes with a Moog arm use it and then replace with a Ford one a couple years down the road
The size of the shaft the bushings and the design is all more robust on the stock one
I know guys that have owned these trucks since 97 Navigators and the like some are on their 3rd and 4th idler arms
It starts wearing out the idler arm threads in the frame
Old Mar 6, 2022 | 07:17 AM
JRS2's Avatar
JRS2
I have some extra parts left over and one happens to be an idler arm for 2.48 " bolt pattern from Detroit Axle. Unused as I upgraded to a larger kit after I purchased this one by itself. If interested let me know, this is still sealed in box. :
There are two different versions of idler arm for these vehicles.
This kit provides an idler arm with a 2.48" bolt pattern. Please consult with your mechanic to verify which specific bolt pattern you have BEFORE purchasing!
MAKE MODEL YEAR RANGE SPECIFIC DETAILS FORD EXPEDITION 1997 - 2002 2.48" Bolt Pattern FORD F-150 1997 - 2003 2.48" Bolt Pattern FORD F-250 1997 - 1999 2.48" Bolt Pattern LINCOLN BLACKWOOD 2002 2.48" Bolt Pattern LINCOLN NAVIGATOR 1998 - 2002 2.48" Bolt Pattern
Old Mar 7, 2022 | 01:49 AM
truckguy92's Avatar
truckguy92
Thanks for the offer but I’ve already got the parts, just waiting for the shocks (went with KYB for the rebate) and time to put everything together. Turn signal lense fell off so now I’m also going to replace all of the front end lighting to the lightning style headlights as well. Hopefully all of this gets done in a single day.
Old Mar 7, 2022 | 09:09 AM
JRS2's Avatar
JRS2
Ok, no problem. Will just save for a future use or if I start selling stuff on ebay may go that way ... good luck with reassembling ....
Old Mar 7, 2022 | 09:21 AM
truckguy92's Avatar
truckguy92
Much appreciated. I’ve helped a friend change their upper and lower control arms on his 4Runner, this ain’t a Toyota so it’ll be a little more straightforward haha
FullLoadOnBoard
1997 - 2003 F150
Jun 3, 2017 05:26 AM
tweak1029
1997 - 2003 F150
Apr 27, 2015 03:58 AM
bumparker
Jan 18, 2012 10:45 PM
00GT
1997 - 2003 F150
Oct 23, 2011 07:22 PM
mikecox1
Sep 19, 2008 12:49 PM
