I joined because I’m about to put a v10 out of a 2016 e350 into a 1964 f100. I’m planning on running the e350 wire harness and pull out the wires I don’t need like air bags and ABS. Hopefully I can pic all your brains as I build this truck.
well others are putting coyote 5.0 and 4.6 pi in there 61 threw 66 and the v10 is the same but longer it shouldn’t be a issue fitting it. I just wish there was a company that supported ford with harness and ECM for hot rod use like they do with GM.
