Jump packs
Old Feb 23, 2022 | 07:12 AM
apstang50's Avatar
apstang50
Jump packs
I’m looking into getting a jump pack to keep in my truck. Looking to see what people have and how you like it.
Old Feb 23, 2022 | 08:20 AM
scraprat's Avatar
scraprat
Top Answer: 5
NOCO GB150 did a fine job jumping the 6.7 when needed.
Old Feb 23, 2022 | 08:22 AM
chadstickpoindexter's Avatar
chadstickpoindexter
I have the NOCO GB150. It’s rated for up to 7L diesel engines and 9L gasoline engines. They also have a GB155 for up to 8L Diesel engines and 10L gasoline engines. I have read and watched a lot of great reviews on these jump packs, which is why I went with it. I haven’t had to use it on my truck, but feel confident in it based on others feedback.
Some pros are that it’s smaller and lighter weight than other battery chemistry types which makes it easier to store and more manageable to use. There are other features to like lights and usb plugs on it too.
Some cons are that it’s somewhat expensive, and that the battery can’t be swapped out as easy as with other jump packs, which would require you to just replace the entire unit.
BackingOut's Avatar
BackingOut
This is the one I have - I thought it was kind of a gimmick until I started using it. I've used it on everything from a lawnmower to tractors.
Old Feb 23, 2022 | 08:45 AM
rna352's Avatar
rna352
The NOCO seems to get good reviews every time this topic comes up.
I use a Clore JNC660 fairly regularly for trailer dumping and winching and for popping off diesel equipment in below freezing temps. It charges with any extension cord and I am always pleasantly surprised at how much power it has even after multiple uses without recharging.
Old Feb 23, 2022 | 09:26 AM
SARDiverDan's Avatar
SARDiverDan
If it’s for a 6.2 engine, I would go with this one. I carry one in my car that has a 6.2 engine.
https://www.ozcharge.com/collections...s-jump-starter
I am not one for always making sure things are charged in case I need them. With this, I don’t have to worry about it.
Old Feb 23, 2022 | 09:31 AM
HRTKD's Avatar
HRTKD
I too have the GB150. It fits great at the bottom of my center console. I keep it plugged into the port inside the center console.
Project Farm (on You Tube) was unimpressed with the Genius Boost, it did not fare well in his test. I have wondered if he got a dud.
Old Feb 23, 2022 | 09:50 AM
The John's Avatar
The John
I have one of these (picked it up for a great price)
Amazon Amazon
it started my buddys 6.7, and lots of other things.
Old Feb 23, 2022 | 06:54 PM
kenners's Avatar
kenners
Another vote for the Noco GB150.
I've got one in each of my 2 vehicles.
Old Feb 23, 2022 | 07:07 PM
Doug Savage's Avatar
Doug Savage
This is one of those items to not go cheap/economical on IMHO. When you need it you NEED it. I carry the NOCO GBX155. I wanted the most juice for a cold start of my 6.7, and hey….Ya ever know when you need to help out a semi driver LOL.
Old Feb 23, 2022 | 07:56 PM
SARDiverDan
post deleted
Old Feb 23, 2022 | 08:48 PM
apstang50's Avatar
apstang50
SARDiverDan what do you mean?
Old Feb 23, 2022 | 08:57 PM
apstang50's Avatar
apstang50
Im not looking to got cheap.
Old Feb 23, 2022 | 09:38 PM
SARDiverDan
I took down my post
Old Feb 23, 2022 | 10:43 PM
12Farmer's Avatar
12Farmer
HRTKD: To which port in the bottom of the center console are you referring? Do you just leave it plugged in all the time?
TIA
