Perimeter Plus Security System
Old Feb 22, 2022 | 06:41 PM
Woodforest-truck's Avatar
Woodforest-truck
I have an early March build date for my 2022 F250 -7.3. Has anyone added the aftermarket Perimeter Plus (motion) Security System? Was it worth it? Any other suggestions for an aftermarket security (alarm) system? Thanks.
Old Feb 22, 2022 | 07:36 PM
JHForman812's Avatar
JHForman812
I have it on my 22 lariat, its just a shock sensor. the truck already had an alarm from the factory but now if you hit the truck or the glass it will set off the alarm.
Old Feb 23, 2022 | 09:22 AM
Woodforest-truck
Thanks Appreciate it
Old Feb 23, 2022 | 10:36 AM
greenno's Avatar
greenno
Got my 2019 set-up the way I want and trying to replace it would be a pain so I went with a Ravelco system. Not the cheapest but they won't be able to steal it. Break in yes but the truck already has the intrusion alarm I just don't want to come out in the morning and it be gone.
Hard to replace stuff nowadays unless you don't mind waiting and waiting.
Old Feb 23, 2022 | 11:02 AM
TB250's Avatar
TB250
In addition to the shock sensor Perimeter Plus adds remote start capability to the stock key fob. Lock-Unlock-Lock to remote start/stop the truck. That was the main reason I added it. Purchased with points and a 15 minute install, made it an easy decision for me.
Old Feb 26, 2022 | 08:12 AM
oilieone's Avatar
oilieone
Trailering
Would you happen to have the installation instructions? Have the sensor, but no installation instructions. Iinstall instructions can only come from Ford website that is only available to dealers.
Thanks!
Old Feb 26, 2022 | 02:22 PM
TB250's Avatar
TB250
Here you go. Had to zip the install manual PDF to get it small enough for the forum.
Old Feb 26, 2022 | 03:37 PM
oilieone's Avatar
oilieone
Trailering
I appreciate you posting these instructions. Thank you!
Old Feb 26, 2022 | 03:46 PM
oilieone's Avatar
oilieone
Trailering
Am I correct in the placement of the VSS module? That the VSS interconnect cable goes behind the display (FDIM) and is connected to the Gateway Module? Or as one of the pictures depicts, behind the OBDII connector?
Sorry if I am over complicating this, just don't want to break a new truck!
Wayne
Old Feb 27, 2022 | 02:41 PM
TB250's Avatar
TB250
The gateway module is under the dash below the steering wheel. I has the OBDII port on it. The VSS can go anywhere in the area. I attached mine to the sheet metal stiffener on the trim piece below the steering wheel. Most people just zip tie to somewhere nearby under the dash.
Old Feb 27, 2022 | 05:13 PM
JHForman812
Wayne
If you have a sync4 truck yes the GWM is behind the screen youll have to take the dash apart.
The GWM being behind the OBD2 only applies to sync3 trucks, it was moved on the sync4 trucks, also its 2 different part numbers depending on which one you have.
Old Feb 27, 2022 | 08:31 PM
oilieone's Avatar
oilieone
Trailering
Appreciate the info. I searched under the dash near the OBDII connector and didn't find the GWM. and the truck has Sync 4. So as JHForman812 says: behind the display.
Attempting to get service at Ford do the install. They can't seem to get a time slot that coincides with my availability. May have to install myself. Any problems with pulling the display? Am I correct in the procedure is to pop the bezel around the display then remove the display?
Old Feb 27, 2022 | 08:42 PM
JHForman812
you have to get this part number for the alarm ML3Z-19A361-A if you have sync4 which you said you have.
Dash disassembly goes like this
1. Remove the center speaker grille(it just pops off)
2. remove the 2 7mm screws holding the center speaker/tray in
3. dead center on the back side of the bezel is another 7mm screw, remove it
4 pop the bezel off and undo all the connectors
5. remove screen
6. remove apim
7. then youll have access to the GWM to hook it up. I mounted my shock sensor down above my right foot up in the dash. this is a pretty easy job and i wouldnt pay a dealer to do it.
Programming it can be a pain to get into but once youre in its easy enough. if you have factory remote start already ignore all the crap about the installation/setup of the remote start its not needed.
Old Feb 27, 2022 | 09:20 PM
oilieone's Avatar
oilieone
Trailering
5. remove screen
6. remove apim
Thank you for the great information! Yes, the truck has Sync 4 and is very well equipped. The previous truck, 2014 F-350, I pulled the display on it to install the Lock-Pick Air system for the ability to add a trailer camera. Why I've worried about puling the 2022 display can only be due to it being new.
I do have the ML3Z-19A361-A part. Should be good to go.
I'll read the instructions on programming again. Shouldn't be too difficult to do.
Old Apr 7, 2022 | 11:40 AM
jeepoff's Avatar
jeepoff
Great thread! I know where my sync 4 gateway module is now.
Does anyone have a pinout for this sync 4 gateway module? I'm trying to find the ms-can wires to tap my canbus snooper so that I can trigger my light bar with highbeams.
