Does anyone know what is different on steering rack between 2006 regular vs extended cab?
the part number is 1 number different between them.. in pics on part store sites they both look the same.
I have a regular cab that needs a rack. And have access to ext cab rack.
just didn't want to pull one for nothing if it won't swap?
im going to look at the ext cab tomorrow, maybe when I can look at them at same time it will make sense? Mounting difference or something? Looks like they use same pump.
I looked up the specs for each one on Rockauto and it turns out the difference is in the lock to lock turns. One is 3.5 turns and the other is 4.06 turns lock to lock.
