Wiped cam lobe will deposit fine metal in the oil filter. Another check is to remove the rocker arms, leave pushrod in, turn engine over by hand without spark plugs, and check each for travel.
I didn’t need to remove the rocker arms. I found about 1/16” of slack in the pushrod for #6 exhaust. All other pushrods had slight tension on them when relaxed.
The valve did move, but travel was about 3/16” less compared to the other valves.
Also noted the oil had a fine metallic sheen. That dashed any hopes of something relatively simple like a collapsed lifter.
I'm glad you found the problem.....I really hate it's not good news....
Anything in the valvetrain is going to more of a tapping noise, and it will be half speed of the crank shaft. Anything in the lower end will be more of a knock, and usually will be on each rotation of the crank.
Depends on the individual. Ive had people call what I take as a tapping noise a knocking noise. So many people hear top end valve train noise they think that is knocking. Out of all my years of working in the field Ive only had bottom in rod knock come into the shop twice and it is a distinct heavy hammering.
Had a fun week trying to get in touch with the warranty guy from the remanufacturer. Lots of phone tag with zero direction of how to proceed. Finally had to go over his head and contact his supervisor. Lo and behold, I got a call back in less than an hour...
My next step is to pull the suspect lifter and send pictures of the face where it rides on the cam. The guy said if the cam lobe has failed, the bottom of the lifter will be scored. Makes sense to me. He also agreed the metallic sheen in the oil points towards a wiped lobe.
Just throwing a Hail Mary here, but is there a way to differentiate between a wiped lobe and a collapsed lifter, without a major teardown? If the problem was only a bad lifter, that's easy enough to fix without pulling the engine. If the camshaft has failed, the warranty guy said they'd replace the whole engine.
Working on my plan of attack now. The metallic sheen in the oil? How much is normal with a brand new engine? I also realize I could pull the manifold and then get to the lifter in situ, but if the most probable cause is the camshaft, I just want to yank the motor and be done. No point tilting at windmills. Plus, my back is killing me lately and I'd like to limit time hunched under the hood.
I sympathize with your pain. I installed my new build that I did mostly myself. I had problems. I had gotten totally screwed by the machine shop. I already had the heads pulled. I had three intake valves that could not hold air. Other than fight with the reassembly in the truck, I just pulled it out.
When the engine was ready I dropped it back in. IIRC, it took about 30 minutes to install the second time. Bell housing bolts, motor mounts and exhaust.
If you must pull and reinstall I can tell you it will be ten times easier the second time.
If the reman rep is willing to warranty your engine you are way better off than most in the same predicament.
Hope your back pain doesn't interfere with your fun.
The way to tell is get a dial indicator and compare the lift of that assembly compared to the others. If the cam lobe is wiped out it will not have as much lift as the others. All the intakes should be the same, all the exhausts should be the same. I see harbor freight has a dial indicator for $17.00.
I measured the travel at the opposite side of the rocker arm. I didn’t have to break out my dial indicator. I could easily see the difference and that valve had about 3/16” less travel.
Something in the valve train was definitely bad. The only question is exactly what had failed? Wiped cam lobe? Collapsed lifter? Wouldn’t they have very similar symptoms?
I am still going on the premise of a wiped cam lobe. Mostly moot now, but is there any way to differentiate before a teardown?
I collapsed lifter would still follow the cam lobe accurately wouldn't it?
I don’t know. IIRC, a lifter has a light spring inside, to keep it expanded. Oil pressure does the bulk of the work, keeping the lifter expanded by hydraulic action. But the spring is there to assist.
So IF (big if) I understand things correctly, a bad lifter will stay extended if unloaded. But put any force on it, and if no hydraulic pressure is present, it will collapse. Remove the force and it will expand again.
Maybe I just answered my own question. Remove the rocker arm so there’s no force on the lifter. Measure the pushrod travel in this unloaded condition, and compare it to the other valves. Even if the cam lobe is wiped, the lifter will stay extended thanks to the internal spring. You’d get an accurate measurement of cam lift.
If that was good, reinstall the rocker arm. Now the lifter will be loaded, as it tries to open the valve. Measure the cam lift again, at the pushrod side of the rocker arm. If same as before, the lifter is good and is not collapsing. If the travel is significantly less than before, you’d know that lifter is collapsing under load.
I think the secret is to measure cam lift unloaded and then loaded, and compare the two values.
Fingers crossed he comes through. It was very frustrating to basically hear nothing all week. I had to be "That guy" and go over his head to get a response. Hope I didn't overplay my hand and he denies my claim out of spite...
Much of the frustration was not knowing how to proceed. The manager at the parts store was very helpful, but he cautioned me the warranty process could be be very slow. In some cases, the vehicle was towed to a shop for a professional diagnosis. With that in mind, I couldn't start prepping to remove the engine in case the truck had to go to a shop.
The whole mess reminds me of going to a restaurant at a busy time. Even if service takes a long time, good staff will acknowledge your presence instead of ignoring you.
Remove the rocker arm to the valve in question. Measure lift while rotating the engine.
Remove rocker arm to a like valve, meaning, if the valve in question is intake, select another intake valve. Measure lift on that valve. Now you will know if the cam is bad or not. With a metal sheen in the oil, 99.9% it's the cam and lifter.
Did you pull the push rod to inspect it yet? I thought I read that the engine supplier said the push rod would be burnt on the bottom if the cam lobe was bad. The metal sheen on the oil isn't a good sign...
Good news! The warranty rep got right back to me this morning. They will get me a replacement engine, handled through my local store. Lots of hoops to jump through, but still better than being left to twist in the wind.
what company reman is this? I dont remember from the other thread?
