Help With EEC Code 96 on a 1991 F250
Old Feb 19, 2022 | 05:35 AM
Bubbz223's Avatar
Bubbz223
Question Help With EEC Code 96 on a 1991 F250
Hey guys, my 1991 F250 with a 351 Windsor has been acting up recently, I can start the truck and it will run for about 30 seconds before idling down and dying off. Then I have to wait about 10 minutes for it to even start again because it will just crank but never turn over. My battery light came on so I checked out the electrical system assuming I had a bad alternator because the voltmeter in my truck is fluctuating and running on the lower side. But it wasn't my battery, starter, alternator, or even my spark plugs so I did an EEC Key On Engine Off test and come back with codes 96 and 18. Code 96 means: Fuel pump monitor circuit shows no power – Power / Fuel Pump Circuits. My fuel pump turns on in both tanks whenever turning my key and I just replaced my o2 sensor, in-line fuel filter and put a fresh idle air control valve in it as well I replaced my fuel injection relay. I would just assume it is my fuel pumps but I can hear them turn on and It doesn't explain the battery light turning on. Before I start throwing random parts in it has anyone had an issue similar to mine that could give me some advice on what to check or replace?
Bubbz223
Feb 19, 2022 05:15 AM
TaddyBare
Mar 17, 2014 05:56 PM
dktool
Dec 22, 2012 12:00 PM
toriumguy
1983 - 2012 Ranger & B-Series
Feb 17, 2005 04:44 PM
kcalabr440
Nov 8, 2004 09:08 PM
