turn indicator problem
Old Nov 6, 2003 | 11:37 AM
jcp2003's Avatar
jcp2003
My 2000 Expedition has a problem - the left turn indicator flashes at double speed (right is OK) is this an easy fix? The 3 year warranty runs out in 3 weeks - should I take it back to be fixed under warranty?
Old Nov 6, 2003 | 01:35 PM
macguyver's Avatar
macguyver
Have you checked the bulbs? Try the emergency flashers and see if one corner doesn't work.
Old Nov 6, 2003 | 02:23 PM
jcp2003's Avatar
jcp2003
Thanks. I have checked the hazards and the rear only flashes one side - does this mean a bulb has gone?
Old Nov 6, 2003 | 02:39 PM
drunkenmonk's Avatar
drunkenmonk
probably a bulb
take off the lens and check it
if the bulb is good check the ground connection
Old Nov 7, 2003 | 09:17 AM
Rick_Ford's Avatar
Rick_Ford
That is the way newer vehicles indicate a bad bulb. I thought it was just Japanese cars, but I guess Ford does it now. On older vehicles, it would just come on and stay solid.
Rick
Old Nov 11, 2003 | 07:18 AM
jcp2003's Avatar
jcp2003
Thanks for your help - it was just a bulb!
