Centramatic wheel balancer road test
Old Feb 16, 2022 | 05:35 PM
KCRebel's Avatar
KCRebel
Originally Posted by Rwhjr
You’re kidding right? People who have had a product fail them don’t post about it?
It’s the opposite most of the time. Those who have something work as expected arent inspired to take the time to post about it since that’s what they thought would happen when they bought the part.
those who get burned by a product, though, love to vent or look for a solution on the internet. So while I don’t believe centramatics suck I also don’t believe they won’t end up working for some. That’s how literally every aftermarket part works with some success rate and some rate of failure.
who knows what the actual numbers are though. And you seem like you’re being disingenuous because usually someone trying to solve wheel/tire imbalances has obviously tried the standard method of getting a tire shop to re balance. How many stories do we hear of “I have had them balanced, road force balanced, etc etc etc” and vibration won’t go away. Why not try centramatics if you’re having issues if you’ve checked the normal culprits of front end vibrations??
I’d think most people trying centramatics are doing so because of current or past issues. Would be an oddball choice to make if you had no existing balance issues IMO. But carry on saving people lol.
There is also a pride factor in that folks don't want to admit they got taken.
To answer your question each time I've read a person chasing a balance or vibration issue I've always recommended checking for bent/warped wheels, warped drive shafts, etc. The problem is there they just haven't found it yet.
Old Feb 16, 2022 | 06:47 PM
morehouse7's Avatar
morehouse7
Yawn.............................................
Old Feb 16, 2022 | 07:06 PM
1dryfly's Avatar
1dryfly
Well that does it for me. I'm going to spend my money on a cold air intake system rather than Centranatic wheel balancers. I don't want to waste my money on something that doesn't work...
Old Feb 16, 2022 | 07:46 PM
PetrolPiglet's Avatar
PetrolPiglet
I'm definitely not an engineer but I know balance beads/airsoft pellets work great for balancing large heavy tires. Centramatics are going to have the weight closer in to the hub but other than that the concept seems to be exactly the same.
How are they snake oil?
Old Feb 16, 2022 | 08:05 PM
Monoman67's Avatar
Monoman67
Originally Posted by KCRebel
These things are modern day snake oil. If you have a vibration something is out of balance, warped or what not. Could be a wheel, drive shaft, lost a wheel weight. These magic rings are simply masking the issue. Not sure why others refuse to accept/acknowledge that. Suggesting that taking off balancing weights which helps balance the tire would make the magic rings work better isn't physics. It's horse dung. Per their marketing those magic rings overcome any imbalance at any speed whether it be snow, mud, or whatever. Until it doesn't.
Thanks for the real feedback. If more of these failures would be reported you would have less of them sold. If I spend my money on something that doesn't work I'm letting folks know so they don't make the same mistake I did. But many won't for fear of being bashed for being negative by fanboys.
Honest question: How are Centramatics not doing the same thing as balancing weights just more specific and dynamic?
Old Feb 17, 2022 | 05:14 AM
B-ManFX4's Avatar
B-ManFX4
Originally Posted by JoeVH
Did you have wheel weights on or not?
I left the wheel weights on. I figured with a slight issue there was no real logic in removing weights - especially since my wheel / tire combo weighs so much to start with.
Wow. Thanks so much for imparting all of us dumb people with your profound knowledge. I especially appreciate being told I am a fool and that the vibration I have been trying to eliminate for over a year really isn't gone with my Centramatic install. I guess I was lucky and picked up a nail in the exact spot that needed it for balancing when I test drove my truck after the installation was complete. When a tire wears it can alter the balance of the wheel assembly. So how is it that something that adjusts on the fly for this continuous wear is "masking the issue" ?
Perhaps you will enlighten all of the minions here with your vast knowledge and experience by explaining how this demonstration is snake oil: https://www.centramatic.com/how-cent...ers-work.rhtml I understand the wheel is much smaller and it's not a direct size / ratio comparison but it demonstrates perfectly that the concept is sound and the physics work - and that when people report it solved their issues they aren't lying or making it up.
https://coursesity.com/free-tutorial...ger-management
Old Feb 17, 2022 | 07:56 AM
Brantel's Avatar
Brantel
Some of you need to spend some time with this channel....
https://www.youtube.com/channel/UCiE...BMpP75JbzJShqw
Snake Oil - LOL
People with issues don't complain - LOL
Do these dynamic balancers have limits on what they can compensate for? Yep, absolutely and the manufacturers are clear on their limitations.
Old Feb 17, 2022 | 08:51 AM
jdnariz's Avatar
jdnariz
I like your sense of humor!
Old Feb 17, 2022 | 09:20 AM
racinwarrior's Avatar
racinwarrior
i see what you did there
Old Feb 17, 2022 | 09:56 AM
mmm635's Avatar
mmm635
Snake Oil - LOL
I agree. Installed a new set of 265's last night and one wheel in particular needed 16oz. of weight. I decided to balance my wheels out with weights this time and use the centramatics to fine tune any wear imbalances down the road from wear. That said, the centramatics will not be able to compensate for the 16oz.
Old Feb 17, 2022 | 12:38 PM
Adam R's Avatar
Adam R
I've spent my fair share of time chasing wheel balance and driveline angle issues across a number of different vehicles and in all of this messing around I have never seen a perfectly round tire. They all have a little hop or slight out of roundness which most people never notice and some tires have major problems which a road force machine should be able to single out. Centramatics will not fix a vibration caused by an out of round tire, broke belts or possibly bent rim. Whenever I get tires mounted, I watch the tire monkeys balance the tire to make sure it doesn't have an unacceptable amount of out of roundness. And if the tire takes more than 3 ounces of weight, I ask them to rotate the tire on the rim and rebalance or find me a replacement.
If someone has a tire issue that re-balancing doesn't solve, it's time to put the vehicle up on jack stands, put it in 4wd, and see how things look when the tire is rotating at speed. A dial indicator also comes in handy if you want to measure the wheel runout, determine if your mounting hub is true, measure driveline runout etc. It's a pain and takes time, but sometimes the problem is more than just a tire balance issue.
Adam
Old Feb 18, 2022 | 04:50 PM
Miles Mac's Avatar
Miles Mac
My Factory balanced F450 tires (drove smooth as glass) started cupping on the edge of the front tires, I promptly installed Centramatic balancers, removed the factory weights, and 10K miles later the cupping is gone (worn smooth) so Bring on the Snake Oil flavored Kool aid !!
Old Feb 18, 2022 | 07:04 PM
  #28
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My Centramatics worked great for me!
Old Feb 19, 2022 | 05:28 AM
  #29
CBANKS's Avatar
CBANKS
You can call it what you want. Your real world experience is far different from mine. Driving the same roads at the same speeds with Centramatics installed has taken vibrations and small shakes to zero. I used to have to wedge a piece of paper in the cupholder to keep water bottles and Yeti insulated cups from vibrating. I don't anymore. I used to have to worry about 5K mile tire rotations. I don't anymore. Driving those same roads at the same speeds has netted an increase in MPG from an average of 12.5mpg to now around 14.5mpg. I am not saying you are wrong. I now have a Cadillac smooth ride for just a couple of hundred bucks. Best $ ever spent on my F250.
Old Mar 26, 2023 | 07:56 PM
  #30
JoeVH's Avatar
JoeVH
I'm going to resurrect this year-old thread with an update, as the original poster. I needed new summer tires, and the tire shop talked me into Nitto Recon Grapplers. I felt like I should try the dynamic balancers again, as I'd like to prevent poor tire wear and scallops. Having sent the Centramatics back for a refund without trying them without wheel weights, my pride wouldn't allow me to re-purchase them, so I bought a couple sets of Balance Masters (MHD-206R). They are a bit smaller in diameter than the Centramatics, which may result in less balancing capability, but I wouldn't be surprised if the mercury they use in them is more effective. I really don't know. Their website just sucks, so I called and spoke with them and they confirmed this was the model number for my truck. Well, the holes in them don't quite fit our lug bolt pattern; they need to be a slightly larger diameter, so I spent some of time hogging out the holes to an egg shape until they fit on the hubs. Conversely, I spent time spray painting my previous sets of Centramatics black, and at least these came black already.
Although I haven't taken them on a long trip, I just got back from testing them for about 20 miles, up to 80 mph on concrete as well as asphalt, and I have to say, they are absolutely smooth. No steering wheel shimmy from the front, no bouncing in my butt from the rears. Very seldom have I ever had any of my trucks drive this smooth. I'm not saying that Balance Masters are better than Centramatics, because I don't know that. I do know that they are twice the price. I also know that removing the wheel weights is something you just need to do and have faith in. Once again, I wish I had tried the Centramatics without wheel weights, but regardless, I'm happy with these and am looking forward to seeing if my tire life increases as they say it should. I would recommend either one of these dynamic balancers.
Also, not to hijack this thread, but the Nitto Recon Grapplers are completely quiet, just like my tire shop told me. Previously, I had BFG's on, and they not only threw rocks worse than any tires I've had, but they also had a bit of a howl to them.
