Turn signal location
Old Feb 14, 2022 | 05:14 PM
dads34's Avatar
dads34
I feel like I've done my due diligence in searching through the threads but came up short. I am looking to replace all my turn signal bulbs to LEDs. I need to find the turn signal relay to replace is. Also, does anyone have a recommendation on brand as well as p/n.
Old Feb 14, 2022 | 06:00 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
it’s all digital now. No relays
you can make the change using ForScan
Old Feb 14, 2022 | 06:39 PM
dads34's Avatar
dads34
As soon as I posted this I saw a video stating exactly what you mentioned. If you go through the scan I saw that you eliminate the function that is for letting you know if a bulb is out. Is thia correct?
Old Feb 14, 2022 | 07:14 PM
ZooDad's Avatar
ZooDad
Basically yes if I am reading your response correctly
ZooDad
Old Feb 14, 2022 | 08:36 PM
dads34's Avatar
dads34
Is there a way around this?
Old Feb 15, 2022 | 06:44 AM
Poncho450's Avatar
Poncho450
I never thought about this aspect but I bet you're right. Because of the low draw of LED, it makes the module think that a bulb is out. And what you're doing in FORScan to eliminate the cluster hyper flash situation is turning the "outage" indicator off.
But as a side note, the hyper flash in the cluster with LED bulbs does not translate to a hyper flash condition when the light is viewed from the exterior. The light will actually be flashing at normal speed from the outside. At least that's been my experience.
TedsRed250
Sep 24, 2021 02:09 PM
greenterror
Electrical Systems/Wiring
Apr 9, 2004 06:58 AM
GeneStoner
Mar 27, 2003 12:36 PM
sixte1f100
Apr 28, 2000 10:13 PM
