I've got a '93 Bronco 302 E4OD with 75k. Within past two months, new cap, rotor, wires, idle air sensor, yesterday i replaced the EGR valve to cure a rough idle. after reinstalling the neg. battery cable, ran great for the first 10 miles or so. but now after driving, when i place the shifter in park, the voltmeter drops, the revs drop and it stalls out. is my alternator dead? i cleaned the contacts on my battery cable/posts and checked the connections. any ideas? this truck has always ran well...
p.s. voltmeter also drops when lights turned on, so i'm guessing maybe voltage regulator?
Doug ,
Is it the original battery ? Have it load tested to see whats going on with it . Also check to make sure the fluid level in the battery is ok . Simple way to check the output of the alternator is place a DVOM on the Pos and Neg cables and check what the alternator is putting out ...you should see 13 to 14V .
Paul
I don't know if it's the original battery, it is a Motorcraft unit, I've only had the car 6 mos., so it might be orig., no date code on case. I'll have it checked first thing in the morning, I'm a college student and I have a lack of tools, so I've got to have it checked professinonally. Thanks-
Doug ,
If Its a Motorcraft its most likely the original battery . A good replacement on a budget if yours is bad is a Diehard from Sears . Thats what is in my F150 and its been a great battery .
Paul
Well, the battery and the alternator both checked out ok. The battery is holding its charge, and the engine always starts right up. My local mechanic and I are stumped. Of course, the vehicle wouldn't cut off for him. He doesn't want to replace things that don't need replacing; now he wants the car for a day to test it.
Doug ,
Have a look at the battery cables themselves from the battery to the starter with the Neg cable and the Pos one from the battery to the solenoid . Im betting one or both are suffering from internal corrsion / acid migration . The Neg one not only bolts to the starter but also to the frame . Its a bare stripped part of the cable that is attached by a clip and bolt to the frame . Ive seen corrosion work its way along the cable from that point .
Paul
