Temp sender
Old Nov 6, 2003 | 06:34 AM
Chumbucket's Avatar
Chumbucket
Temp sender
Is the water temperature sender located down below distributor forward into block the one that feed's temp gauge at dash. 92 300.
Old Nov 6, 2003 | 09:00 AM
larry derouin's Avatar
larry derouin
NOPE!
Gauge sender is in the head, Passenger side, right around the intake for #6 (meaning all the way in the back and damned near impossible to get to). Look for a single wire sender.
Larry
Old Nov 6, 2003 | 03:49 PM
Bhanna4d's Avatar
Bhanna4d
It is a wierd connection that doesnt look like it would stay on ,atleast it is on my 90, but so far I have had no problems. It is directly below the end of the fuel rail and right where he said it was by #6 exaust. If you crawl underneath you can see it by looking in between the manifolds and the chassey
Old Nov 6, 2003 | 06:26 PM
Chumbucket's Avatar
Chumbucket
OK, Thank's Guy's . Just put the cardboard away from new oil pump and screen LOL. It wasnt like this in the old Flathead day's with all these wire's,sensor's ,relay's and code's . Oh well
