Preventative maintenance while front end is apart
Old Feb 10, 2022 | 07:57 AM
wellsf's Avatar
wellsf
I’ve got a 2014 f350 6.7 that has had a leaking primary radiator but has recently gotten worse. So last night I ordered a new one and got the old one taken out. While the truck is down and this far apart I would like to do any preventative maintenance necessary on the front of the engine. I was thinking the belt and tensioner first but is there anything else that can be done while I have the front this much apart.
Old Feb 10, 2022 | 11:50 AM
djousma's Avatar
djousma
How many miles on her? Belt is good idea. What about replacing some of the larger radiator hoses and maybe thermostats while it is drained down? I used to do that back in the day, but things were much simpler then.
Old Feb 10, 2022 | 11:55 AM
wellsf's Avatar
wellsf
She's nearing 200k. Thermostats are a good idea. I think im gonna go with a motorcraft oem belt and tensioner about $200. I will look into finding some newer hoses... wish ford didn't use these retainer clamps on these big hoses with their brittle ford plastic.
Old Feb 10, 2022 | 12:08 PM
Pugga's Avatar
Pugga
Belts and hoses are all that come to mind. Thermostat was a good suggestion. Otherwise, you can check all your wiring harnesses for chaffing and making sure everything is staying nice and secure.
Old Feb 10, 2022 | 05:58 PM
FishOnOne's Avatar
FishOnOne
Primary water pump...
Old Feb 12, 2022 | 09:01 AM
Overkill2's Avatar
Overkill2
Check and see if the vacuum pump bolts are tight on the front of the engine.
Old Feb 12, 2022 | 09:48 AM
DTEC907's Avatar
DTEC907
Orings for the hoses!!
I have a bunch of coolant on top of my engine due to the oring for the thermostat housing hose being worn flat and it hit -20F.
Old Feb 15, 2022 | 02:24 PM
speakerfritz's Avatar
speakerfritz
body mounts
FarmingF250
Jan 8, 2024 12:47 AM
jerryparks
20
Jan 29, 2022 11:27 AM
gtex
Dec 2, 2020 01:09 PM
broncoxlt
May 23, 2018 02:09 AM
killacash
Escape & Escape Hybrid
Jul 5, 2013 08:24 AM
