Oil leak
Old Nov 6, 2003 | 03:38 AM
TERSEJR's Avatar
TERSEJR
Oil leak
I have recently developed an oil leak at the back of the oil pan. There is a small metal cover under the starter moter and fly wheel I think is where it is coming from. I tightened the last oil pan bolt and cleaned the oil off, and it does not seem to be leaking from the pan, just that cover. Is there a seal or gasket inside that cover that could have gone bad? The weather has turned cold , and now it leaks enough to leave a puddel where ever I go. Any help would be usefull. 2000 F350 auto 122,500 miles and counting.
Old Nov 6, 2003 | 06:34 AM
powerstroker250's Avatar
powerstroker250
Check the top of the engine first. Most leaks originate there and run down the back of the engine.
Old Nov 6, 2003 | 05:31 PM
TERSEJR's Avatar
TERSEJR
Thanks powerstroker250. You were right. It is coming from the top of the engine and running down the back side. I park up-hill. I can see that it is leaking from under/ around the fuel filter where it meets the engine. Can't see any thing obveous. Any ideas. Thanks.
Old Nov 7, 2003 | 06:49 AM
powerstroker250
High pressure oil pump or high pressure oil line o-rings since you say its coming from the front.
Old Nov 7, 2003 | 10:25 PM
TERSEJR's Avatar
TERSEJR
That's what I am thinking ,but haven't the foggiest on how to fix it. Any help would be helpfull. Can turn a wrench pretty well! Thanks.
