Sponsored by: Real Truck
Towing
Old Feb 9, 2022 | 05:31 PM
Skidmore's Avatar
Skidmore
Originally Posted by redford
I've known guys that tow 6000 pounds every work day, not a huge load for these trucks.
Thanks. I appreciate it.
Old Feb 9, 2022 | 05:39 PM
Skidmore's Avatar
Skidmore
Originally Posted by '65Ford
Check/rebuild suspension, brakes, and steering. Catch up the maintenance, flush and change ALL fluids. Replace brake hoses (and lines if rusty). Make sure tires are 6 year old or less. Then start towing your 6000 pounds.
That is my plan. Thanks. I just got this truck about three months ago so as soon as we get away from this sub zero weather we are having here I will get to doing my own inspection and fluid change all around. Long story short. I lost the steering on one of the work trucks I used to drive. It had a valid inspection sticker. After that I just don't trust anyone with a safety inspection.
Old Jun 4, 2023 | 08:43 PM
Skidmore's Avatar
Skidmore
Overdrive While Towing
I am going to guess that towing a trailer that is close to max weight capicty in overdrive is not good. I am not sure. Any body have any ideas on that?
Old Jun 4, 2023 | 08:58 PM
PROSTOCK's Avatar
PROSTOCK
Details on your truck would be supremely helpful.
Old Jun 4, 2023 | 09:25 PM
85e150's Avatar
85e150
I moved your overdrive question here. I don't know which transmission you have, but the later ones are OK in overdrive UNLESS you can't hold OD and are "hunting". I that case, take it out of OD or any other gear it won't hold and run it at a safe RPM in the next lower gear.
Fiveacre
Aug 31, 2021 01:10 AM
Fiveacre
All Things Towing
Aug 27, 2021 08:50 AM
haffner226
6.2L V8
Jul 23, 2014 08:59 PM
yoda
All Things Towing
Oct 27, 2003 07:51 PM
86Betty
Sep 14, 2003 08:40 AM
