Turn signal problem
Old Feb 7, 2022 | 03:38 AM
brain360's Avatar
brain360
Turn signal problem
So I have a 79 f100 and when I have all the lights off on the truck my turn signals and hazards work fine but as soon and I pull the **** to turn in headlights and parking lights my turning signals stop flashing, why?
Old Feb 7, 2022 | 07:10 AM
TJDentside's Avatar
TJDentside
If you’ve got trailer hookups check and make sure someone hasn’t wired your turn signal wires ( green and yellow I think) into the brown wire somewhere.
Old Feb 7, 2022 | 10:41 AM
Mark8man's Avatar
Mark8man
When did the problem start? Is it all the turn signals or just right or left? Unless someone was doing some creative wiring, I am guessing the turn signals are getting their ground through the headlamp filiments (due to poor grounding elsewhere) and once the HL's are turned on it prevents that from happening.
Old Feb 8, 2022 | 11:49 AM
meangreen92's Avatar
meangreen92
Those ground wires are two in the front and two in the rear. The front ones both bolt to the radiator support, and the rears are behind the taillights, and bolted to the bed.
Old Feb 14, 2022 | 11:06 AM
wdon's Avatar
wdon
Turn signal problem
I had the same problem on my '79 F-100. The main problem (there were also some bad connections, etc.) was that a towing connector was improperly wired to the taillights.
Old Feb 14, 2022 | 01:57 PM
HoustonDave's Avatar
HoustonDave
(my perennial line) also check that the ground strips inside the socket side are solidly hooked to the ground wires themselves. When that connection goes, you can polish the screwed in ground points forever and still have the symptoms of a bad ground.
dmarsh2400
Aug 19, 2019 03:23 PM
gbaileytx
1983 - 2012 Ranger & B-Series
Dec 26, 2004 09:42 PM
tatwood
Jun 5, 2004 12:52 AM
79Tomato
Feb 15, 2003 12:12 AM
