Sponsored by: Auxito
Bad mileage
Old Nov 5, 2003 | 10:26 PM
silverman's Avatar
silverman
Unhappy Bad mileage
I own a 2000 f150 4*4 with a 4.6 its lifted 6 inches with 315/75/16 tires and im getting 10 miles to the gallon on the interstate is this right. If not whats the problem, I had it hooked to a snapon code puller and no codes were found someone help please. The air filter has been checked.
Old Nov 6, 2003 | 11:42 AM
MisterCMK's Avatar
MisterCMK
You posted this in the wrong forum, but there are a few things you can check. First is the tire pressure. Make sure that they are completely inflated. Also, check that your plugs are good, and change the fuel filter. A tune up can do good things for your vehicle.
Old Nov 6, 2003 | 03:02 PM
dfisher1's Avatar
dfisher1
Silver,
Is the vehicle lacking power at all? Is the exhaust loud and clear, does it rumble or is it subdued, (hissing)?
Kingfisher
