proportioning valve sensor
Old Feb 1, 2022 | 04:43 PM
sklbaj's Avatar
sklbaj
The brake light in my cab has been on for some time. I figured the issue was in the two wire plug in the proportioning valve so I took it apart today. In doing so I discovered its made of a plastic housing. Mine had pretty dirty connectors so I cleaned them up and reinstalled. No more light so for the time being the problem is solved. When looking at the plastic housing and threads on this little sensor my threads were worn pretty bad. Looks like a cheap part I just need to know where to find it. 1971 f100 2wd
Thanks
Old Feb 1, 2022 | 06:21 PM
1browski's Avatar
1browski
I found this one.
https://www.macsautoparts.com/1967-1...8-41766-1.html.
found better price
https://www.dennis-carpenter.com/car...warning-switch
Old Feb 2, 2022 | 07:28 AM
sklbaj's Avatar
sklbaj
That looks like what I need. Thanks. It looks like that part is for ford trucks from 1967 to 1996. You would think it would be easier to find, and more available.
Shiro
Apr 6, 2014 11:02 AM
02GrayPowerStroke
Jan 17, 2008 06:52 PM
goofinoff
1997 - 2003 F150
Sep 12, 2005 01:49 PM
countryboy4_1qt
Dec 17, 2004 04:52 PM
