Sponsored by: Real Truck
Which rear end?
Old Jan 27, 2022 | 08:04 PM
willtim1234's Avatar
willtim1234
Which rear end?
I have a 2013 F350 4x4 6.2 l with 4.30 gearing. The differential has an electronic locker. How can I find out which rear end I have? Thanks
Old Jan 28, 2022 | 09:55 AM
SDSC4X4's Avatar
SDSC4X4
There should be a tag on the differential. A dealership should be able to decode it for you or run your VIN and tell you. There might also be an axle code on the door sticker (there is on my '01) that they can decode.
Old Jan 28, 2022 | 10:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
If the truck is an F-350 SRW you have a Ford (Sterling) 10.5 differential.
I don't think the locking diff option was offered on the DRW trucks. IIRC, those came with Dana 80 differentials.
Old Jan 30, 2022 | 06:59 PM
00t444e's Avatar
00t444e
Count the amount of tires you have on the rear axle, 2 tires is a Ford 10.5, 4 tires is a Dana 80. Also the E locker was only in the Ford 10.5.
79CAMOFORD
Sep 24, 2011 01:32 PM
D2Gags6.0
May 18, 2009 12:52 AM
brmkart14
Jun 11, 2004 11:14 PM
jopey
Feb 17, 2002 03:39 PM
