No start no crank!!
Old Jan 25, 2022 | 10:03 AM
Greenleaf1935's Avatar
Greenleaf1935
No start no crank!!
Hi friends , I’m a new member 1st time classic truck owner. I have a 1965 ford f-100 , and the solenoid has a rapid click when trying to start I also have a new starter and battery . I have even taken off to have checked they shows there good I changed the cables and also put in a aftermarket key switch , still no crank, no start will someone tell me what might be the problem. Thanks for any advice given
Old Jan 25, 2022 | 02:48 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Have you tried jumping across your solenoid? They are cheap and easy to replace.
Old Jan 25, 2022 | 03:36 PM
66F250_4x4's Avatar
66F250_4x4
Sounds like a dead-ish battery, or bad connection. Mine used to do that intermittently b/c the battery cable was poorly attached to the battery clamp. I'd jiggle the cable, and it would crank just fine. I finally fixed the problem correctly.
Since you have a new battery - check the battery clamps and make sure they and all the other connections are clean and tight.
Old Jan 25, 2022 | 04:13 PM
1966F100SC's Avatar
1966F100SC
Check ground cables, you would be surprised even if a cable looks just a little corroded it can make a big difference
Old Jan 25, 2022 | 05:06 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I'm going to add another vote for dirty/loose battery cables. Undersized cables, bad ground, loose connections anywhere between the battery, solenoid, starter.
Old Jan 26, 2022 | 05:40 AM
Greenleaf1935
Thank you all, it was driving me ,no where after going over the checks again making sure
things were tight
and cables clean . I happened to loosen up the starter to see that it binding although I could turn the motor by the crank bolt. I think that I might have to shim the starter. The transmission was removed since the last start I just hope the flywheel is not bent and the
torque converter were fully seated.
again I really appreciate your help.I’ll give you an update later this frozen morning.
R33df250
New Member Introductions
Aug 2, 2016 09:20 AM
carlos velez
Dec 2, 2007 10:23 AM
