Need advice
Old Jan 23, 2022 | 03:32 PM
DoubleStacks OBS's Avatar
DoubleStacks OBS
Trailering
Need advice
Hello all thanks in advance I am moving to ok from ca and u haul is 7000.00 so needless to say am buying a f250 ones to pull 16ft trlr since my diesel is already out there don’t you love life anyways I am going to see a 1997 heavy duty 7.5 and have never owned 460 any advice or suggestions to help or things to look at much appreciated
Old Jan 23, 2022 | 04:31 PM
torq'ta 5 8's Avatar
torq'ta 5 8
I will assume you know your in the 6-8mpg hauling, if your lucky.
Check all fluids, before starting it up, and then check again when test drive is over, see if they have the right color tint, to them, will let you know if it has/hasnt been changed, look around engine, see if it looks clean/dirty/nasty, look underneath for oil leaking, trans leaking, and if 4x4 diff covers leaking, miles? If you had a paperclip, you could check for codes, by watching check engine light flash,
see link-->Fuel Injection Technical Library » How To Run a Self-Test
(16) How to read a check engine light code on a Ford 1983-1995 EEC 4 system - YouTube
Old Jan 26, 2022 | 04:25 PM
jtab's Avatar
jtab
Look out for broken exhaust manifold bolts. Particularly the rear ones.
JeepTech27
Sep 19, 2021 05:46 PM
Cbrummett111
15
Jun 22, 2021 12:34 PM
Bajabound88
Feb 1, 2016 07:17 AM
cherie1
General Diesel Discussion
Jan 31, 2008 10:20 AM
Sprint11
Jul 15, 2006 05:46 PM
