Forescan Connection Issues
Old Jan 22, 2022 | 06:17 PM
mdalby's Avatar
mdalby
I am having issues getting my adapter to connect on my truck. Do I need to use a different adapter? I have the ignition key turned on.
Adapter: OHP FORScan OBD2 ELMconfig Adapter
Amazon Amazon
Old Jan 22, 2022 | 06:21 PM
projectSHO89's Avatar
projectSHO89
Did you first set up the adapter in Forscan?
Old Jan 22, 2022 | 06:34 PM
RLXXI's Avatar
RLXXI
...also flip the switch the other direction and try again.
Old Jan 23, 2022 | 06:17 AM
rbentnail's Avatar
rbentnail
Sometimes you have to hook up a battery charger. The BMS will cut off aux power to several things at the most inopportune times. I found out the hard way, right in the middle of trying to enable the Bambi mod.
And, depending on the adapter, you may have to download drivers for it to work. I did.
Old Jan 24, 2022 | 06:10 PM
Siberexpress's Avatar
Siberexpress
Is the fuse good?
F2spiffy
20
Aug 3, 2021 05:23 AM
PhilPalmiero
2021+ F150
Apr 17, 2021 05:40 PM
49fordv8f4
Oct 28, 2020 08:10 PM
Overkill2
6.7L Power Stroke Diesel
13
Nov 9, 2019 08:13 AM
Curated Content Editor
General Automotive Discussion
Apr 6, 2018 01:17 PM
