Electrical Help
Old Jan 22, 2022 | 03:39 PM
Andy83Urena's Avatar
Andy83Urena
Electrical Help
Hello, I'm new on forums and not too savvy so excuse the lack of know how. I am working on my 1979 f100 I6, no ac, manual 3 speed. I recently replaced the voltage regulator, battery, alternator and all battery cables to include from the starter to the starter solenoid because the truck is not charging. So with that being said I obviously have other issues. I have tested the components individually and determined they are functioning as they should. I have read that fusible links would cause the no charging issue but am at a loss as to the wiring my truck has. It was my understanding that there should be a fusible link between the alternator and solenoid but seem to have more and dont see visible damage. I would greatly appreciate all the help I can get. I have posted pictures of the wiring...
Old Jan 23, 2022 | 10:37 AM
440 sixpack's Avatar
440 sixpack
The fusible like can burn out and not be visible. but on the ones I've lost if they're out nothing works.
Does your amp meter work ? I'm not sure on Ford but sometimes if the amp meter goes it interrupts the charging circuit .
Do you have 12v to the main hot wire on the when you turn the key on alternator ? if it's not there you're not connecting to the battery.
Old Jan 23, 2022 | 11:26 AM
meangreen92's Avatar
meangreen92
I'm pretty decent with electrical in these trucks because they are mostly simple. If you don't have a multi-meter, go ahead and get a cheap one at the hardware store or where ever, and get one with a continuity testing function. Then you can check for continuity on both sides of the fusible links. Or if you have some understanding, and the parts laying around, you can make a test light with nothing more than a marker light bulb, socket, and pigtail, off of a junk vehicle.
A meter will also allow you to check for voltage at points where you know the voltage should be.
When my fusible link went in my truck, the truck was idling, and died just as I was reaching for the door handle to get in and drive away... But everything in the truck was dead, so I immediately suspected that the battery had gone stone cold dead. Mine was up by the starter relay/solenoid, where the battery positive cable connects. I think I just have bare wires at the alternator, but I don't think I've ever removed or disconnected my alternator in 5+ years I've had my truck - which has to be some kind of record for me.
Old Jan 23, 2022 | 11:27 AM
HoustonDave's Avatar
HoustonDave
This is by memory so may not be 100% accurate when it comes to wire colors: wife and I were leaving a local gun show when the alternator light came on. The truck was still running well, so stopped at a local FLAPS store who tested and said the regulator was out: bought one - no joy. Knew we were running on a draining battery with evening coming and 30 miles to home, so we wound up hitting three stores en route (for their one regulator in stock apiece!) At the last store an older guy who owned a '79 came out and asked if anyone had checked the fusible link? Sure enough, wired around it and all was handled. Anyway, a $7 fusible link (16A, I recall) and a few minutes' work the next day restored everything, and in the year plus since then, has held up fine. I want to say it was between that rectangular connector in your pics and the solenoid on the larger black/brown wire? but that is where my memory is not exact.
Old Jan 23, 2022 | 12:24 PM
Andy83Urena
My truck only was equipped with the warning lights so no amp meter.
Andy83Urena
15
Jan 24, 2022 11:34 AM
Andy83Urena
Jan 22, 2022 03:41 PM
ChrisParker1
Dec 6, 2021 12:33 AM
80BullnoseF250
16
Jan 1, 2021 02:03 PM
SleeprLegend
15
May 6, 2010 10:28 PM
