Fuel gage off?
Old Jan 21, 2022 | 02:49 PM
Pappawheely's Avatar
Pappawheely
Fuel gage off?
I have a 92 F350 CC 4x4. All of a sudden my fuel mileage dropped significantly. I never calculated the fuel usage, I just know the gage drops fast, and I have to stop frequently. I saved a couple receipts and noticed I am not using the gas I thought I was. The other day I had less than half a tank in front, and the rear was under a quarter. When I stopped for fuel, I topped both tanks but only filled 23 gallons. It seems like I have an extra 10 gallons that does not show on my gages. Can my gages be reading wrong? Is that an electrical issue, or normal degradation? I'm curious to see if others have noticed this.
Old Jan 21, 2022 | 03:00 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Can the sending units be wrong? Yes. I’m a little unclear if the gauge off by the same amount. If so then I’d say that the gauge might be the problem since each tank has its own sending unit.
Old Jan 22, 2022 | 11:20 AM
Conanski's Avatar
Conanski
No the gauges in these trucks are not even remotely accurate, and the variation between units is all over the map. With my old '90 the front tank would show full forever and then suddenly drop like a rock and the rear tank was almost the complete opposite. New senders probably won't entirely fix this problem... just give you different results, so my suggestion is to run one tank at a time right down until the motor starts to die before switching over, and take note of the miles driven to get an idea of the true range available. If that uncovers a real problem like you can't use more than 1/2 of a 19gal tank then it's quite possible it has the wrong fuel delivery module and fuel level sender in it.
GloveGuy
Feb 11, 2017 06:00 PM
Old Brown Truck
Oct 7, 2014 08:17 PM
pbgsho2
Nov 27, 2010 07:33 AM
motopsyko32
Jul 7, 2010 08:38 PM
Smoke2008
6.4L Power Stroke Diesel
Sep 22, 2009 07:04 PM
