Would anyone be able to point me in the direction of a good single barrel manual choke carb? Ive seen ebays covered in them and autozone an oriellys offers one as well. Is one better than the other or are they all the same?
I got a manual choke YF from United Automotive. Little bummed they ground off the casting number but it was an original and in great shape. I've got a driver so I wasn't too upset but if I was reselling down the line I would expect one with the castings!
Be aware if you change from one to the other, you'll have to modify the choke linkage slightly because the pull different. Also they are slightly different air cleaners. If you have an original air cleaner hold on to it tight!
