2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
F150 pulling 5th wheel
Old Jan 19, 2022 | 01:40 PM
f150_fx4's Avatar
f150_fx4
I currently have a 2011 f250 diesel that has 188k miles. It has been trouble free but it's getting to the point of where things are finally getting worn out and needing replaced. I don't think I want another diesel cause of high maintenance cost and I don't tow much. I have a 30' 5th wheel that my diesel can't even tell its there. I believe the max weight of it is 8000lbs. It's stored away for the winter so I can't tell for sure.
My dad has a similar 5th wheel he pulls with his 2019 f150 with the 3.5 ecoboost max tow and he says it does good other than the 9 mpg. My diesel gets 11 pulling my 5th wheel. Is this to much camper for a 2021 f150 3.5 eco with max tow? Or do I need to look at the 6.2 f250? I'm torn cause I don't want a payment but I don't want to keep taking truck in to get fixed. Thanks
Old Jan 19, 2022 | 02:46 PM
dustyroad's Avatar
dustyroad
you need to look at the gvwr and see if it's rated to pull that. I think 150's are too small for that setup.
Old Jan 19, 2022 | 03:21 PM
f150_fx4's Avatar
f150_fx4
I tried looking up tow ratings and it shows conventional and 5th wheel/gooseneck for everything but the 3.5 ecoboost
Old Jan 20, 2022 | 08:39 AM
johndeerefarmer's Avatar
johndeerefarmer
I towed both my 26' and 32' fivers with my 17 F150 but it has Super Springs and performance mods. As long as there is no wind you are fine. Once the wind gets up to 15-20mph the wind will blow you all over the road. When Ford lightened up the F150 by making it out of aluminum they ruined them for towing.. Stick with the SD
Old Jan 20, 2022 | 05:17 PM
jcnorton's Avatar
jcnorton
I'll probably get roasted for this but I have to give you a heads up on the 6.2. I had a 15 SD with 6.2, don't know how the newer ones compare but the 15 was gutless. No bottom end at all. With 4500 # on a flat bed, 3:73 axel running from Indiana through Michigan to Ontario cruise set at 75 - 3rd gear screaming like little girl trying to pull every hill unless I intervened by putting it in "M" and shifting manually . I have no idea how guys are pulling trailers the size of yours it would drive me nuts, it lasted 2 years and sold it. loved the truck, hated the motor.
Old Jan 21, 2022 | 12:15 PM
Fefanatic's Avatar
Fefanatic
I fish with a buddy around Missouri lakes. He has a '14 SD with a 6.2. It screams with a 20' bass boat behind it. It also gets around 7-8 mpg doing it. I wouldn't recommend a 6.2 for any towing. I do understand the new 7.3 does a better job.
Old Jan 21, 2022 | 12:19 PM
Fefanatic's Avatar
Fefanatic
To the op, set up a box or similar in your bed where the 5th wheel plate would be and back under your trailer and lower your stiff legs onto the box. Step 20' or so away from the truck on the side and take a look. Is the front end raised up? Is the rear sagging? If so then I wouldn't recommend towing. It doesn't matter how much hp to pull it. It matters whether the truck can control it. Front end up it won't be a pleasant ride.
Old Jan 21, 2022 | 12:27 PM
seventyseven250's Avatar
seventyseven250
Agree that engine is the least important part of this question. Suspension and geometry will be key.
Old Jan 22, 2022 | 12:26 AM
sub1187's Avatar
sub1187
I’ve done it with a 7450 lbs 5er. Towed it through the mountains and through the valleys of the northwest with an 04 f150 max tow and also my 18 f150 with regular tow. Both were v8s. I was within specs on payload and towing. The 18 was better geared for towing but the upgraded sumo springs did let me know it was there. Obviously you’re not going to do 80 with the trailer but it is done by myself and others without concern. The nah sayers are just that but they also don’t tow with facts just what they are comfortable with.
Old Jan 22, 2022 | 07:25 AM
Fefanatic's Avatar
Fefanatic
That might work until you lose control on a mountain highway and kill someone. Don't do it in Colorado. They will prosecute. There's always someone that says "hold my beer". If you're going to do a job get the right tools.
Old Jan 22, 2022 | 08:33 AM
f150_fx4's Avatar
f150_fx4
We have a 2012 f350 regular cab with 6.2 on the fire department for a brush truck. I thought it was gutless too but i thought it was cause the I believe 200 gallons of water in the back. That's why I was considering it but then realized 7.3 is probably better. Stopped at the dealer yesterday but couldn't pull the trigger. They offered me 17,000 for my 2011 f250 diesel with 188k miles. I was only going to use trade in as down payment and can't justify going from 0 truck payment to 600. I have decisions
Old Jan 22, 2022 | 08:40 AM
f150_fx4's Avatar
f150_fx4
I currently havd a 2011 f250 diesel i was considering to replace. My dad has a 2019 f150 crew cab long bed with 3.5 and max tow. He was told by multiple people he is fine pulling his similar 5th wheel. It looks like it sits fine. Now that I'm looking to replace mine I hear conflicting answers. I don't want to be overloaded. Dealer priced me a f250 with 7.3 and after A plan it would be 53000 plus tax. He said a similar f150 would be just a couple thousand less. So I think I'm sold on a f250. Just sold on a payment
Old Jan 23, 2022 | 09:34 AM
BLK79's Avatar
BLK79
Going from that diesel to gas towing - the gas will never "feel" as comfortable due to the huge torque difference. Diesel lopes along, gas revs to the moon (or feels that way), not hurting anything but completely different experience.
Same with F250 vs F150. 150 won't "feel" near as comfortable/stable as the 250 does. Doesn't mean it's not capable if within towing specs.
For me would depend on the frequency and distance you plan to tow. A lot - the 250 diesel wins hands down. A little - gas 150 may be a better fit.
Old Jan 23, 2022 | 09:53 AM
f150_fx4's Avatar
f150_fx4
I have had thus 6.7 powerstroke for 6.5 years. I originally bought it to tow a 5th wheel. I didn't end up buying a 5th wheel until this past August. I was borrowing my parents camper that they rarely used and this truck was really an over kill. I ended up towing a camper maybe 4 or 5 times a year probably 200-250 miles on average. Longest trip was 400 miles. Besides that I towed a dump trailer of wood 2 times. So really I haven't used it for it's full potential. I bought the truck with 41k miles and it now has just over 188k miles. I understand the gas vs diesel won't feel the same. I love how when I hit the pedal the diesel just moves and it never really down shifts when towing. I'm just sick of all the maintenance that goes with it. The 120 oil change, the 50 fuel filters, the Def. The almost 11k upgrade is insane and I can buy alot of gas for that. I priced out the diesel back in June and was all set to have one built but after my trade in my payment would have been 725 and that was a tough pill to swallow. The 7.3 I just had priced out that I'm contemplating would be 550 which is still a tough one but that's the same price my diesel was when I bought it used. Sales guy said a f150 vs f250 isn't really much of a difference
Old Jan 23, 2022 | 10:49 AM
Wiggums's Avatar
Wiggums
Your diesel may get slightly better gas mileage but I would not be surprised to see the 3.5EB giving you a lot more power. Now, between F-150 and F-250.. the F-250 may handle the weight better but has the older dashboard and less tech features compared to the F-150. Not only that, the interior space is the same which was why I didn't buy an F-250. Get a smaller trailer and use the F-150 hybrid as a generator.
