Sponsored by: Real Truck
Manual hubs
Old Jan 18, 2022 | 07:19 PM
joepa330's Avatar
joepa330
Manual hubs
Got an 02 F350 7.3. Driverside is Warn manual hub, passenger side factory manual lockout. Driverside grings, like it's engaging, just not all the way. Took it apart, everything moves like it should. Tried spinning axle while locked, won't move, so it's somewhat grabbing. I'm perplexed.
Old Jan 19, 2022 | 10:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'd inspect the stub axle U-joint on that side.
Old Jan 20, 2022 | 02:47 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Agreed with the above.
I would also consider making the hubs match - not a fan of having mismatched parts on the front axle.
Old Jan 21, 2022 | 07:26 AM
Tumbleweed1972's Avatar
Tumbleweed1972
Try swapping the hubs side to side and seeing if the noise follows the hub. Could be that your hub is failing.
schmitty99
Jun 2, 2012 09:40 AM
quality1construction
Mar 4, 2008 07:47 PM
honeyb
Jun 19, 2005 12:36 PM
RANGERMAN1
1983 - 2012 Ranger & B-Series
Dec 22, 2004 11:21 AM
bertcakes
4 Cylinder Engines
Dec 19, 2003 06:09 PM
