steering column porblem
Old Nov 5, 2003 | 02:11 PM
trailer-ed's Avatar
trailer-ed
i have a problem with the steering column that was recently put in my 1977 f-150 (auto/ 2wd). The shifting column seems to have shifted over and i have lost park and reverse. Is this fixable or a lost cause?
Old Nov 5, 2003 | 03:31 PM
mattsf250's Avatar
mattsf250
not sure what you mean, did the column portion that moves "slip" in relation to the shift tube inside?
i totally rebuilt my 78 F250 column a couple months ago...got everything needed from jeff's, i think it cost me about 100 in parts, and about 5 hours including r&i of column, and fitting a new borgeson steering shaft in as well. works as good as new now, and required no special tools at all. very simple.
good luck!
Old Nov 6, 2003 | 11:16 AM
loudfords's Avatar
loudfords
Are you sure the column is at fault? You can adjust the shift linkage where it connects to the tranny, there is a slot so you can coordinate the detents in the tranny shifter arm with the gear positions in the column.
