I’ve got my distributor pulled out now. The plug going into distributor/pickup coil disintegrated in my hand. The middle prong had been melting the plastic very slowly.
I ordered a motorcraft cap and rotor and a standard ignition pickup coil from oreillys and reading another thread here someone mentioned not buying the exact pickup coil I just bought and buying one from Napa. I trust Napa a little more so I’d figured I’d follow their advice.
Long story short Napa lists 4 pick up coils for a 1979 f250 3/4 ton. I can’t find any kind of drop down menu to select a specific engine. I have a 400
They list 2 Napa Echlin brand coils with 36 month warranty’s and 2 Proform coils with 12 month warranty’s.
Napa number ECH MP700 and ECH MP712
Proform numbers MPE MP700sb and MPE MP712sb
In each of the different models then sell a 1974-1989 version and a 1975-1983 version. All are listed as “High Altitude”.
Which one should I get? Is there any real discrepancy between 1974-1989 and 1975-1983? There is a price difference with the Napa 36 month 75-83 model being the most expensive by $10 or so. I’m leaning toward buying that one. I’m open to other stores or anywhere else. I couldn’t find a real Motorcraft pickup coil anywhere.
Make some resistance checks.
Between orange and purple wires should be 400-800 ohms (preferably 600-650 ohms).
Between the black wire and ground should be zero ohms.
Between orange wire and ground (& purple wire and ground) should be at least 70,000 ohms (preferably infinity ohms).
The plastic surrounding the stator's coil should not be cracked.
If you have a choice on country of origin, USA is to be preferred over China.
I bought 2 bad Standard brand ones in a row. they're crap.
If you look on ebay you can still find NOS ones, Prestolite and a few other older made in the US ones. if you have to use a chinese one to get it going now watch for a quality one to replace it. Jeep ones starting in '78 are the same and seem to come up for sale more often.
