Does anyone know if there is a mod for changing rear axle gear ratio for larger tires within forscan? Figured I might as well do that at the same time I calibrate speedo.
If there is does anyone have references or calculators to do so? Also I have the LED box lighting head lights or the "C" shaped lights and wondering if anyone has come across the mod to have double function as the led headlights and the blinker in yellow when in use? I know I have seen that in passing on the road.
Well I was just asking a generalized question as to if there was even the option for those changes and if there was then I would provide such details but if there's not such a things then there's no point in wasting time tying and giving those details. With that said the important points to determine an answer is it a 2020 Ford F250 6.7 Diesel.
I've never clocked how long it takes typing "2020 Ford F250 6.7 Diesel" but I see your point.
