Sponsored by: Auxito
2000 F150 weird electrical issue
Old Jan 15, 2022 | 06:15 AM
bcompton35603's Avatar
bcompton35603
I had posted earlier that when this truck was idling in the driveway the starter kept trying to engage. It no longer does this, but the running lights and taillights stay on and the lights on the instrument cluster and radio will come on and go off every few seconds, all without the key in the ignition. GEM and ignition switch has been replaced and most of the electrical harnesses pulled apart and dielectric grease applied before put back together. Have looked at most of the ground points and they look ok. Even took them off and sanded them before tightening back down. Not sure where to go from here.
Old Jan 15, 2022 | 06:51 AM
bcompton35603
well, I stand corrected. The battery runs down because the running lights and tail lights stay on and everything else turns off and on. I also found the blower will run as well. I put the battery charger on overnight and just cranked the truck, and lo and behold, the starter kept trying to engage.
Old Jan 15, 2022 | 12:31 PM
projectSHO89's Avatar
projectSHO89
It help if you keep everything in a single thread instead of scattering stuff across multiple posts.
Old Jan 15, 2022 | 06:44 PM
bcompton35603
When I posted this, I thought I had fixed the original problem and this was something new. Turns out it is the same problem.
bcompton35603
1997 - 2003 F150
Jan 31, 2022 09:52 AM
Fordguy05
Apr 11, 2019 12:06 AM
nickyhatch
Mar 18, 2011 11:35 PM
daggerNC
Dec 11, 2010 11:50 PM
chickenrun
1997 - 2003 F150
Apr 24, 2004 11:44 PM
