Flareside fuel tank(s)
3rd time’s a charm
Takes:
1. Cleaned out tank using muriatic acid. Although it was a smoking try , I failed to rinse and dry quickly. New rust formed which caused the POR to peel. If done correctly, this would’ve been the best option as we coated the old tank exterior with rubberized under coating. Now I have an RV Cummins oil drain pan?”.
2. Ordered Spectra tank from Amazon. This was an old, tried tank with multiple scraps dents and weld splitting.
3. Ordered a SpectraPremium tank from EBay. Received with small dents as it is very thin walled, but it is primed with a shiny grey. We added some AutoZone “Boom Mat” for anti-rattle/anti-chafe, and are finishing up the install.
we are struggling with installing a new roll-over vent grommet (not found at any part stores other than Ford dealer/EBay/Amazon.
Can’t wait to get Ole Balu on the road!
This comes with 4 precut pieces. We installed 2 on top, “ripped” one into two for the bottom, and have one left over for other squeaks, creaks, or water leaks.
The roll-over vent grommet use a little oil or liquid soap on it.
I think I installed the rubber first then lubed the valve & grommet and pushed in the valve.
I did this x2 and had no issues.
BTW I got the grommet from either LMC or Dennis Carpenter think LMC with new valves.
I used new rubber hose from valves to the metal lines that run up to the canister(s) under the battery for fumes.
As for cleaning and coating the inside of the tanks I am not a fan of because if not done 110% right the coating can come off and cause problems.
Dave ----
Dave ----
Do over
We will have the opportunity to replace that vent hose and try the soapy water to install the vent valve. This is because we have the rear 19 gallon sending unit installed, so we’ll install the correct 16 gallon sending unit tomorrow.
Teaching my son about verifying parts as son as they arrive.
Takes:
It's asian and it isn't the same kind of steel used by spectra . Why does it make a difference?
spectra uses a ni-tern metal that is a lot more resistant to rusting, That asian tank is straight sheet metal with some sort of paint on the outside.
Spectra doesn't paint their tanks.
So consider your reason for going dual. If you need the range alot then having the capacity makes sense. But if it's only occasionally needed you might want to consider a couple jerry cans strapped in somewhere.
Once you've had dual tanks it is hard to think about not having them. With diesel it's really nice to have them when you forget how low on fuel you were on one of your tanks and you're running out you can flip the switch quickly for a recovery. Running out with diesel is a pain because now you have air in your system.
So think it over on the dual tank set up. You may decide it isn't worth the expense and time to do a "Dave" on your flareside.
On the road
Thanks all for the input. I don’t believe this truck has realty been in the road for a decade or two.
After double checking the first tank I purchased was a SpectraPremium with an etched type finish. Unfortunately that one was received fairly beat up, so it was returned. The second tank, pre painted and now installed, was a no name. The sheet metal is extremely thin, but it is working fine.
This truck with be for short trips only, so a single tank will be fine. I do wish there was alternate fill pluming to use the one existing flareside fill door to connect a rear 19 or 38 gallon tank though.
You would need to put the nozzle in through the wheel opening to fill it.
This is what my rear fill looks like with the flare side door glassed in looking in from the wheel opening.
You might be able to point the hose to the front for the nozzle to fit. Might need a bracket off the frame to hold the hose up.
Then again no one side you have to glass the rear door into the fender. You could work out something like on the older pick ups where they did not have a door, the cap was just there. If you were to put the hole & mount it like that I would put it in the location the door would go this way if down the road you want to add the door you would be cutting out that hole.
Dave ----
I keep a coat of Fluid-Film on midship tank as well. (Actually a coat of Fluid-Film on pretty much the entire truck).
I think with the peel and stick boom mat you won't have to worry about moisture getting under it causing potential corrosion. But the slip on boot while good as a shield may provide a place for moisture and or salt to reside. If I was you I'd put a generous coat of Fluid-Film between the boot and tank. And a light coat elsewhere on the tank. But that's me...
#28
bfree65
15
06-11-2022 09:22 AM
ccc822007
08-17-2021 12:03 PM
Dallas2142
08-07-2018 06:27 AM
terrylamar
49
08-12-2016 11:06 PM
dgmontoya
09-24-2010 11:19 AM
