Seized bed bolts
Old Jan 14, 2022 | 01:44 PM
1996F150LongBox's Avatar
1996F150LongBox
Seized bed bolts
I just purchased a 1996 f150 with a long box and am having trouble getting at the bed bolts under the frame as they seem to all be seized or stripped, any tips?
Old Jan 14, 2022 | 02:18 PM
My4Fordtrucks's Avatar
My4Fordtrucks
They are carriage bolts. All of mine spun when I tried to remove the nut so I had to grind the heads off. Good luck.
Old Jan 15, 2022 | 05:45 AM
2dwoods's Avatar
2dwoods
Start with a 1/4 " drill bit dead center on head then go bigger until head pops off
Old Jan 16, 2022 | 10:49 PM
McLeod's Avatar
McLeod
weld large nuts to the top side of the bolt head.
I replaced them with hex head bolts instead.
Old Jan 17, 2022 | 07:33 AM
AHenry014's Avatar
AHenry014
I had to cut off the side of the heads of some of my bed bolts and had a friend grip them with vise grips while i was under the truck removing the nuts. There are newer style bolts available that feature a clip-style nut that slots onto the frame in the 6 locations needed. The bolts themselves are giant button head allen's. The bolt/clip-nut kit is pretty cheap on amazon/ebay. They are marketed for newer trucks, but work just fine.
Old Jan 17, 2022 | 07:39 AM
Bad68Ford's Avatar
Bad68Ford
You can try cutting a slot in the top of the head with a small die grinder and cutting wheel. I used a Dremel. Worked good for two of the bolts but the last one I had to weld a nut on top of it. Should've done that first to save the hassle.
glenn7
May 31, 2021 12:00 PM
Jbay123
Aug 24, 2019 06:33 PM
electod
Sep 30, 2012 05:27 PM
kjg26
Sep 15, 2006 05:58 PM
Scott123
Aug 11, 2005 08:33 PM
