Sponsored by: Real Truck
Sagging front leafs?
Old Jan 13, 2022 | 11:22 AM
JustinLB's Avatar
JustinLB
Should it be arched backwards like this? Can I take them and have them reached if so? Does it just need new ones?
Old Jan 13, 2022 | 11:37 AM
nydiver's Avatar
nydiver
Its always been alot of weight to put on 2 leafs, then to compound those mini packs aren't helping anything. So yes, they will arch a bit like that. You don't need a new main pack necessarily, but a real leveling kit of long leafs to replace those 4 pieces of plate steel will definitely help it, its ride, and the longevity of the leaf pack.
Old Jan 13, 2022 | 11:49 AM
JustinLB's Avatar
JustinLB
Alright. What's a good brand to use that won't cost me a whole lot? It's got roughly 3" in that lift.
Old Jan 13, 2022 | 12:08 PM
nydiver's Avatar
nydiver
The kit I've used a few times is this one:
https://www.summitracing.com/parts/sum-g781
Has the track bar bracket and the long add-a leafs. The front leaf does not go inverse at rest once these go on, and they're progressive. BUTTTT Summit claims they are out of stock til march. But it gives you a visual of what the kit your looking for should include. Maybe rough country, superlift, or BDS has a leveling kit like this one. Also there is another kit at Summit for diesels (a little more arch in the leafs) it too is backordered to march.
EDIT: Found em. Tuff country makes these kits for Summit. gas is 22961 diesel is 22962. A quick check find gas around 285 for the kit, but I'm sure you can do better.
https://www.sdtrucksprings.com/index...4aAkqHEALw_wcB
Stengel Bros is who I order leafs from, they have extra leaf, heavier duty leaf springs also, probably more expensive (~500-600 for a new pair of higher capacity, lift springs) but that's another route to look at. You'll want the track bar drop bracket too, that is around 120.
farmer2114
Jun 29, 2021 08:18 AM
CSIPSD
22
Jul 25, 2012 11:37 PM
WA.Ranger
Feb 28, 2010 05:23 PM
