Timing chain help
Old Jan 12, 2022 | 06:12 PM
Patina65's Avatar
Patina65
Timing chain help
Replacing gaskets on my motor and I have timing chain exposed, so with me not knowing anything about his motor I decided im going to replace the timing chain as well sense im here.
advice on timing chain to order, thanks!
I have a 390, not built.
Old Jan 12, 2022 | 06:22 PM
85e150's Avatar
85e150
What kind of chain is on it? Is there slack in it? Is the upper gear covered with nylon?
What year is the engine?
Old Jan 12, 2022 | 06:38 PM
Patina65's Avatar
Patina65
there is slack, seems like a lot from videos I have seen. I don't know what kind of chain is on it, looks like ones in the videos I've watched who upgrade from stock. the truck is a 65' I don't know if its the original engine or not.
Old Jan 13, 2022 | 12:20 AM
85e150's Avatar
85e150
In a '65 the OEM V8 was a 352. If your engine is painted all blue and the paint looks like it was OEM, it is a '66 or later engine. Not uncommon to see swaps as there were billions served.
So if it has slack, it won't hurt you to replace it as long as you are in there. Be carefull with debris falling into the pan.
Old Jan 13, 2022 | 01:06 AM
Patina65's Avatar
Patina65
yeah it’s painted all blue, down to the oil pan and the only paint that has really lasted on the motor are the valve covers.
do you have a recommendation on what brand timing chain/ gear set to get?
Old Jan 13, 2022 | 02:46 AM
Thunderkiss1965's Avatar
Thunderkiss1965
Cloyes timing chain set. Well established brand.
grizzqc
May 12, 2008 06:24 PM
nk_andr
Feb 3, 2007 01:39 AM
ford390gashog
Jan 19, 2004 12:53 AM
