Trailer light issue
Old Jan 12, 2022 | 05:58 PM
Slackerme's Avatar
Slackerme
Trailer light issue
22 350
Having some issues with trailer lights on multiple trailers that didn’t give me trouble on my old truck 2 weeks ago
At any rate
I’m getting a trailer light module fault on dash
also right turn signal not working but when I hit the breaks it goes away then pops back up as soon as I use the turn signal
so what I have troubleshooted so far is that the right side turn signal works intermittently
no left turn signal at all
when I tested 7 pin on truck with multi meter I’m only getting 5.6 volts off left side and 6.8 on right side. Maybe that’s why right side led turn signal works intermittently
obviously I have warranty and that’s what my route will be eventually but I am headed on a 1000 mile snowmobile trip this weekend and I’m sure the dealer won’t be able to get me in before then
any in-site to the possible issue would be great
thanks
Old Jan 12, 2022 | 06:08 PM
crewzer's Avatar
crewzer
Check the trailer wiring harness connector on the back side of the bumper-mounted 7-pin connector is clean and firmly seated.
HTH,
Jim / crewzer
Old Jan 12, 2022 | 06:12 PM
Slackerme's Avatar
Slackerme
Will do in the am
Old Jan 12, 2022 | 07:35 PM
TIMM250's Avatar
TIMM250
Had the exact same problems that you're having plus intermittent brakes not working with the screen showing that fault and trailer disconnected long after the trailer has been disconnected. All my trailers worked with my 2018 and with the 2022 all these things have been happening. Replaced the trailer socket on the truck with an aftermarket one. That solved my problem on the 2018 a couple of years ago and it solved the problem on the 2022. Takes 2 minutes to replace it. Wasn't worth my time or effort to take it back to the dealer.
Old Jan 12, 2022 | 07:38 PM
Slackerme's Avatar
Slackerme
That’s funny
My last truck was 2018 as well
no issues with it
well ****
Old Jan 12, 2022 | 10:13 PM
slurugger's Avatar
slurugger
Following, had the same issue on my 15 and now experiencing on my 22. I thought maybe the trailer had a bad ground or something...not sure.
Old Jan 12, 2022 | 10:34 PM
NedFletcher's Avatar
NedFletcher
Had this issue on a 16 f150, unhooked the back side of the 7 pin, sprayed both sides with wd40, hooked it back up and it worked fine
Old Jan 12, 2022 | 11:35 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Originally Posted by Slackerme
22 350
At any rate
thanks
I haul a number of different trailers, and get the right turn signal fault warning on a couple of the trailers with LED lights, but the turn signal always works, but sometimes takes a flash or two to start, and the warning never comes on until about 2 to 4 seconds after the signal is shut off.
I haven't worried too much about it because the turn signal works, even if it takes a flash or two to start.
purplewg
2009 - 2014 F150
May 20, 2021 10:29 AM
cgn9tom
Apr 24, 2020 08:58 AM
kpriddy
Electrical Systems/Wiring
Mar 23, 2009 12:49 PM
1997stroker
Sep 25, 2007 06:54 PM
bud121156
Escape & Escape Hybrid
Jun 30, 2007 04:38 PM
